Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Ignition failure 330xi
      12-06-2005, 03:13 PM   #1
lungdoctor
Drives: 330xi
My 2006 330xi failed to start today at the WaWa ( coffee stop). Car started out of garage without difficulty, but after the coffee stop ( 2 miles from my house) the car failed to start. Car has comfort access. The dash computer first showd an icon a person with the seatbelt on and the airbag deployed. ( air bag is not deployed and the car hit no bumps or other objects on the way to the WaWa). Then a picture of the steering wheel with a lock above it was displayed. The starter motor starts but the car will not start. BMW assist was great and the car was towed to the dealer. I just spoke with them (Thompson BMW), and they can not get the car started , and have not seen this problem before. The car has been at the dealer 8 hours. Anyone have a similar problem. The dealer has not seen this before. Is this a software issue or a sensor or hardware problem. For now they have provided me with a toyota- Not the ultimate driving machine. Any suggestions or comments Thanks I have asked them to call Germany for suggestions. Please Help I want my baby back. any suggestions would be greatly appreciated
Dr. A
      12-06-2005, 03:16 PM   #2
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
Did you try put the key in?
The steering wheel lock icon means that the automatic steering wheel lock couldn't disengage (and hence the car won't start)
I had it once, and all i did was move it side to side until the lock was free to move and it worked.
      12-06-2005, 03:25 PM   #3
E90Fleet
South Africa
1312
Drives: BMW
As broken1 said the steering wheel and lock is the electronic steering lock fault warning
was it red or yellow ?
If yellow the engine wont start till you get the lock to disengage by moving the steering wheel back and forth
      12-06-2005, 04:08 PM   #4
thrill30
South Africa
16
Drives: 2010 E90 330i 6MT
I once had a similar issue(I also have Comfort Access)... there was an elaborate error message on the iDrive screen with icons and all.... the error mentioned that I mustn't shut down the engine... but the engine was already off as I had just stopped to refill gas/petrol .
See my post at: http://www.e90post.com/forums/showthread.php?t=6121
In any case, to solve the problem, I put in the keyfob and the car started without a problem.... I later reported this behaviour to the dealership , and they told me that they know of similar issues on the 7 series... and the workaround is to put the keyfob into its slot and start the engine... then book the car in for a check or software update.
As Broken1 asked: Did you try to start with the keyfob in its slot? If you did try this, then you might be having a different problem.
E90 330i 6MT|Space Grey|Red Brown|Alumin|Sunroof|Voice Control|Logic 7|Xenon|Prof-Navigation|Storage Pack|Luggage Pack|Extended Lights|Anti-dazzle Folding Mirrors|Climate Comf. w/screen|M-Sport Pack|Exclusive Pack|Innovations Pack|Alumin Pedals|CF Splitters|Delivered:19 March 2010
      12-06-2005, 04:54 PM   #5
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
So in other words, you can turn the engine over, but it just refuses to properly start and run on its own. Do I understand your post correctly?
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      12-06-2005, 05:21 PM   #6
LEDZEP
LEDZEP's Avatar
418
Drives: 2009 E70 & 2011 F25
I'm just thinking how damned funny it would be if wiggling the steering wheel has eluded the BMW shop monkeys for eight hours!
I hope they at least gave you a good loaner!
I think it is bad luck to be superstitious
      12-06-2005, 08:21 PM   #7
lungdoctor
Drives: 330xi
Ignition Failure 330xi
I tried to start the car with the key fob in the dash, and the car still would not turn over. I did try turning the wheel and the car still did not start. The steering wheel with the lock was yellow in color. Thanks for your help. The car is at the dealer, and as of 5 pm, they still have not gotten the car to start.
      12-06-2005, 08:23 PM   #8
lungdoctor
Drives: 330xi
Ignition Failure
The Loaner is a Toyota- It starts every time, but it is not the ultimate Driving machine. The steering is way to loose, and the interior is all plastic.
      12-06-2005, 09:03 PM   #9
btc
btc's Avatar
63
Drives: 06/330i/SB/TERA/AL
2006 330i  [0.00]
have you check the battery safety terminal (BST) ?
http://www.e90post.com/forums/showth...hlight=battery
      12-06-2005, 09:26 PM   #10
lungdoctor
Drives: 330xi
Ignition Failure 330xi Being Towed From WaWa
To the Dealer
[IMG]
      12-06-2005, 09:29 PM   #11
lungdoctor
Drives: 330xi
No I did not even open the hood, because I had power in the car. The lights worked and the car would turn over, but not start. I will call the Dealer in the morning and ask to have the BST checked Thanks. Dr. A
      12-07-2005, 06:40 AM   #12
btc
btc's Avatar
63
2006 330i  [0.00]
BTW, your battery is located in the trunk. When the BST disconnect, it still give you power to lock, un-lock, play the radio, call sos, and light.
      12-07-2005, 09:15 AM   #13
hkspwrsche
Drives: 81 911sc,82 911SC
This is one Ive been waiting for
I've been waiting to see what reliability problems might show up and this one was mentioned in the car and driver article, wasnt it? The test car wouldnt start right away? Is this only an issue with comfort assist? This is my fear that if I buy a fancy eletronic controlled everything car that it will break down right away on me. Ive got 2 911 SC's that start right up and a little 91crxsi for the snow. I really want a new car but, reliability is worrying me....on new porsche and bmw stuff.
      12-07-2005, 06:48 PM   #14
lungdoctor
Drives: 330xi
I had the Dealer Check the Battery and it was fine. Thqanks for the suggestion. The dealer finally got the car to start, and has narrowed the problem to a communication module. The have ordered the part and hope to have the repair completed 12-8.Thanks again for everyone's suggestions. I will post the resolution once I have my Baby Back.
      12-14-2005, 07:40 PM   #15
lungdoctor
Drives: 330xi
330xi Now Fixed And Running Great !!!
Failed Main Relay was replaced FP Number 61-36-6-901-469 (I think this is ignition relay)
Also replaced- Control Unit FP number 61-35-6-981-416.
The Car is back like new. Just returned from picking up my daughter at Syracuse University ( Winter Break ). This car is so much fun to Drive, 4.5 hour road trip with navigation and great sound-no time to get bored or get fatigued.
      12-14-2005, 11:40 PM   #16
myXI
myXI's Avatar
Drives: 330XI
Sorry to hear that you had issues with the car. It's good that things are resolved, and your baby is back on the road.
330XI ,SGM, 6MT, Black Leather, ZCW, ZPP, Aluminum trim
