Parrot ck3000 evolution bmw e90
08-24-2013, 02:31 PM | #1 |
Rep 58
So i recently installed the parrot ck3000 evo with the connects2 adapter! All my controls work but im am getting no sound out of the speakers! I also dont hear the "menu" when i push the center knob. Any ideas?
08-27-2013, 05:05 PM | #5 |
18
Rep 629
I have the same setup. I remember I had a problem at first and it ended up being the connection to the Parrot control pad... If I recall correctly, it connects with a small black connector with 3 or 4 pins. You CAN plug it in wrong! If you look at it carefully it is keyed, but I had mine plugged in wrong at first. Unplugged it and plugged it in correctly and everything started working.
Good luck and please report back! |
08-27-2013, 09:57 PM | #6 | |
Rep 58
08-28-2013, 06:11 AM | #7 |
18
Rep 629
Bummer. I was hoping that was it. I would pull everything and double/triple check all of the connections are tight and correct. That one little connection threw my whole system off, it didn't just affect the control unit. It just shows what one wrong connection can do to you.
There's also a reset you can do to the Parrot. You'll have to check the manual but I think it involved holding down both buttons for a number of seconds. |
