Car won't start. . .at a loss
08-23-2013, 08:19 PM | #1 |
Rep 44
So I go out this morning and my car won't start. All the electronics are there, but nothing turns over. Take the battery out and get it tested and it tests strong. Home diagnostics test shows it good, take it to the store and they show it good. Do some research, can't find anything else that relates except the starter. Go through the unnecessarily enormous task of taking out the Intake Manifold to change the starter. Take it in and have it tested before I bought another one, and it was good as well. I don't know what else to do. I'm really at a loss. I will likely change the starter, just because I went through all the trouble to pull this crap out. The battery is from 2009, so I guess it could be bad but there has been no symptoms of anything failing.
08-24-2013, 09:29 PM | #2 |
33
Rep 648
Could be a bad brake switch (AT) or clutch switch (MT). Scan for bmw specific fault codes, if you can't do this call someone who can or tow to an indy instead of throwing parts at it. Remember when installing the starter to hook up that little wire or the car will not start.
08-24-2013, 09:33 PM | #3 | |
Rep 232
08-25-2013, 05:49 AM | #5 | |
200
Rep 1,834
Drives: '05 E90 330i Manual
08-29-2013, 08:18 AM | #8 |
200
Rep 1,834
09-04-2013, 08:26 PM | #9 |
Rep 4
My car will not start. The radio is the only thing that turns on? It will not kick on dash lights and the battery tested at 11.7 today. I have been reading online to wiggle the red wire next to the fuse box in the older 06-07 e90 models, any ideas?
09-04-2013, 08:47 PM | #11 |
Rep 4
E90
So even though your battery was testing normal the computer system would not let it power up your car? Did you pull any codes or weird dash lights before the problems? My light bulb light was on the day before and from my reading it may indicate a bad battery.
09-04-2013, 10:25 PM | #12 |
33
Rep 648
If you're pretty sure that its the starter at least have it bench tested. A bad starter (from my experience) will still draw power and drain the battery so that's something to look at.
09-05-2013, 12:10 AM | #13 | |
103
Rep 2,783
If the radio is the only thing that turns on then it probably is the battery |
09-05-2013, 11:43 AM | #15 |
964
Rep 3,854
Drives: 330i, 135i
yeah I agree with posts above. Do a load test on your battery. Take battery to an Auto parts store and have them do it. It should be free since they want to sell you a new battery. Keep us posted.
09-05-2013, 01:29 PM | #17 | |
964
Rep 3,854
Drives: 330i, 135i
After I changed my battery radio now stays on for about 15 min and then turns off. this is normal. Cheers! |
