The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > 335is Track Mods
      08-18-2013, 01:36 AM   #1
bjf66
51
Drives: E92 335is DCT
335is Track Mods
Hi,
Just finished my first track day and I had lots of fun. Ran into limp mode on the 4th run, because I was driving hard and shifting late, but overall it was a fun day.
What mods do I want if I want to do this more often?
I am thinking:
Performance friction brake pads
SS brake lines
Brake fluid
What about getting a bolt-in rollcage like the one VS Motorsports had?
I don't want to do suspension right now because I want to go with M3 bits later, and that would require me to get M3 shocks.
Any brands/mods/suggestions are good!
      08-18-2013, 02:42 AM   #2
EJ_3
EJ_3's Avatar
371
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
Since you don't want to do suspension, I say braking and cooling. Might want to change your rotors too, BMW rotors are soft. Definitely get an intercooler, especially if doing multiple runs.
      08-18-2013, 09:07 AM   #3
CJ421
CJ421's Avatar
1559
Drives: BMW M3
I'd prioritize stopping power first. High-temp brake fluid and upgraded pads. I use this fluid in my car: http://store.vacmotorsports.com/tota...115-p1790.aspx
Cooling, you'll want to do an FMIC. I have an ETS 5" model and have yet to have a limp mode (though I am N55 engine).
Lastly, tires; Michelin Pilot Super Sport is the king of street tires right now.
Good luck.
P.S. you won't be able to fit M3 dampers on your car without significant modification (read: not worth it).
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      09-10-2013, 12:07 AM   #4
paddy335
66
Drives: M140i;X5 40d
high performance pads
racing brake fluid
road legal track tyres
I would only go for more cooling based on your local climate. For cooler climates the stock IC/OC/radiator are fine.
Don't shift so late, you're out of your optimal hp/trq point and just stressing/heating the engine at that point for no gain.
      09-10-2013, 02:39 AM   #5
ashmostro
1254
Drives: 2020 M4cs | 2022 M550i
Like the others said, cooling cooling and braking.
Our cars suffer with both on track. not too hard to fix though...
      09-10-2013, 12:41 PM   #6
joepants23
Drives: 2013 e92 335is
2013 BMW 335is  [0.00]
I am taking my 2013 335is on the track for the first time. I have a Dinan Stage 2 and free flow exahust mods. anything I should be thinking about as well? i see lots of brakes mods
      09-10-2013, 06:01 PM   #7
paddy335
66
The bare minimum is high performance pads and racing brake fluid. You'll put a lot of wear on your road tyres too, depending on the track.
      10-10-2013, 12:34 PM   #8
yomny
yomny's Avatar
16
Drives: '13 335is 6spd
What do you guys recommend as far as double duty pads? You really dont think the stock rotors could hold up? Thanks.
Karura- how was your stock suspension handling the turns? I find my oem stuff to be quite soft(rebound).
Was considering the ER sports cooler, do you think kits any better than the AR design add on cooler?
PS- do not mean to thread jack, just want to contribute.
Linky
Linky
      10-10-2013, 12:48 PM   #9
ashmostro
1254
I run racingbrake XT910 pads on ECS slotted geomet rotors (essentially stock) with Castrol SRF fluid. I boiled RBF600 on my first track outing and decided to go all out.
With this setup and no additional cooling, I never run out of braking power, but do get pad smear near the end of my more spirited sessions, but that goes away when I step it down. I'm building a cooling system to address that but otherwise I don't currently have braking issues. If I get a lot faster, I might need to get more aggressive with my pad selection (mine is a hybrid street/track pad out of convenience).
      10-10-2013, 12:52 PM   #10
ashmostro
1254
FWIW I prefer replacing the existing core if you have one due to less pressure drop and complexity overall. But I don't really have anything bad to say about the AR setup.
I will say all oil cooler kits for this platform are stupidly overpriced.
      10-10-2013, 01:10 PM   #11
yomny
yomny's Avatar
16
Thanks for the feedback man. I was thinking Hawk HPS, im not an aggressive driver at all, i yet have much to learn about road course driving. I had ferodo ds2500 on my STi and well those were great but not on the street. If i have to do a sreett setup and a track setup i wont mind but i rather not. I'll check out the ones you have. Thanks.
      10-10-2013, 02:37 PM   #12
ashmostro
1254
You bet. Keep me posted and good luck!
      10-11-2013, 06:44 AM   #13
joepants23
I put those hawk hps brake pads with motul 600 fluid and ecs stainless steel lines. I thought it ran pretty smooth in poconos. It was also my first time on the track. I didn't have any problems with cooling.
      10-11-2013, 07:40 PM   #14
yomny
yomny's Avatar
16
Thanks, good to know. I dont want to go too crazy on pads since i dont track too often but i do enjoy it.
      10-12-2013, 01:55 AM   #15
TurboBimmer
TurboBimmer's Avatar
Luxembourg
79
Drives: F82 M4
The AR design kit is way undersized for the track! Get the ER sports Kit and you'll be fine. Trust me, I've tried both
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
      10-12-2013, 09:13 AM   #16
yomny
yomny's Avatar
16
Thanks, i considered the AR because the ease of installation but it really makes no sense to have an extra cooler with the oem stacked, simply adds more oil. I guess ER it is. Thanks for the feedback.
      01-08-2014, 06:29 PM   #17
Patronus86
Drives: 2013 335is
2013 335is  [0.00]
I know this totally reviving a dead thread, but I have a legit question on oil cooler options for the 335is. So I'll ask it here instead of starting a whole new thread:
The 335is already comes with an upgraded oil cooler. Is there any product that supplements that oil cooler, or do you have to gut the stock and install a whole new system for track work? From the sounds of this conversation, it seems the AR oil cooler supplements the stock one. Why would this not work for track days?
      01-08-2014, 07:05 PM   #18
bjf66
51
Bump, would like to know ^ too. Good question.
      01-08-2014, 07:51 PM   #19
ashmostro
1254
Kind of odd... it seems the question was answered with three different perspectives already- and that was quoted by the person that just asked.....?
      01-09-2014, 07:58 AM   #20
yomny
yomny's Avatar
16
If I'm not mistaken the 335is doesn't haven an oil cooler any different than the regular 335i. It has an additional smaller radiator and a heavy duty radiator fan but the oil cooler is like any other. The point of not adding another cooler is to be efficient and not redundant. Instead of having two average units, you replace it by one good one.
      01-10-2014, 03:07 PM   #21
Patronus86
Drives: 2013 335is
2013 335is  [0.00]
Yeah, that's what I don't get. Why is having a secondary and primary oil cooler not as efficient as simply having one bigger oil cooler? Does the oil not equally flow through both oil coolers when you have the dual setup?
      01-10-2014, 04:01 PM   #22
ashmostro
1254
Why have the added complexity? Why cover up the primary radiator with yet another secondary oil cooler, thereby making the radiator less efficient? Why have additional pressure loss associated with more complex plumbing and restrictions?
