BMW w/ OEM Alarm can't open TRUNK with key
08-17-2013, 08:40 PM | #1 |
21
Rep 200
Hi Guys-
I purchased my 335i with the oem alarm installed from the previous owner. It's a pretty cool system however I can't open the trunk with the FOB. If I unlock car and manually open it works and also works with button near kick panel. With remote control if I press and hold for 2-3 seconds. Nothing happens, If I continue to press the panic goes off.. That leads me to believe the button on remote control is good. I have another bmw and trunk opens fine with key. I'm 100% its not user error. Any chance it code me a coding issue? |
08-19-2013, 07:44 AM | #3 |
295
Rep 2,202
It could be that as well. If you have the coding sheet; see if you could disable the panic alarm in DWAI module and then try again with fob.
Does your car has CA?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
08-19-2013, 11:20 AM | #4 |
21
Rep 200
It does not have CA. I never use the panic but if I can keep it and fix the problem. It would be nice.
08-19-2013, 03:14 PM | #5 | |
295
Rep 2,202
