Walnut blast question!
08-17-2013, 10:40 AM | #1 |
16
Rep 198
Drives: 08 328xi E92
as the title says I have a question about getting a walnut blast done on my 328xi coupe. Ive seen and heard of alot of the 335 guys getting it done and was wondering if I get it done will it make that much of a difference to justify it on my 08 328 with 60k on it. Or how do I know if I need it? I know kind of a newb question, dont flame just trying to find out about it. Also I did search and couldnt find anything about it being done on a 328. Thanks
08-17-2013, 10:54 AM | #4 |
289
Rep 864
Direct Injection
You should not need a walnut cleaning. DI do not have the intake valves washed with fuel -- throw in a turbo and 245F temps, long oil drain intervals and you are left with intake valves that are caked with gunk. You may have dirty injectors -- just run a little seafoam & top-tier gas.
08-17-2013, 12:00 PM | #5 | |
65
Rep 507
side ? tho are you the first owner of the car.. second ?
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
08-17-2013, 12:10 PM | #6 |
1435
Rep 4,724
You do not need a walnut blast.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
08-17-2013, 12:12 PM | #7 |
Rep 51
Drives: 2010 335i
General walnut blast question for the N54: At approx how many miles do you guys recommend to have the intakes blasted out? Do any dealers offer this under warranty or is that just a pipe dream? Anyone running a catch can right after a walnut blast and if so, does it totally cut out the problem or just delay the necessity for another walnut blast down the line?
Thanks in advance |
08-17-2013, 12:21 PM | #8 |
16
Rep 198
im the second owner I bought it with just about 50k on it. I always run and always have run shell V-power since I bought it. Ive heard mixed reviews on sea-foam, and have heard that its hard to use, please correct me if im wrong and what the proper way to use the sea foam would be? Thanks
08-17-2013, 12:34 PM | #9 |
26
Rep 606
Buy a bottle of Lucas fuel treatment and put it in your tank when it's full of gas then, when you drive throughout that tank, occasionally give it full throttle to really push that cleaner through the injectors well.
08-22-2013, 02:59 PM | #10 | |
65
Rep 507
I would spray off your MAF sensor just because a dirty one can result in poor gas mileage ECT. http://www.e90post.com/forums/showthread.php?t=490389 \ if your MAF is dirty it will result in poor milage and on my friends N52 it was seemed to cause the car to shake while under acceleration. also i use this to prevent carbon buildup ( keep in mind its for a 335 but im sure it couldn't hurt to do on the n52) http://www.e90post.com/forums/showthread.php?t=694228 last but not least always use top tier gas TOP TIER Detergent Gasoline Retailers "Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline." here is the the list > or some of them BP Chevron Conoco CountryMark Entec Stations Exxon MFA Oil Co. Mobil Ohana Fuels Phillips 66 Quik Trip Road Ranger Scheirl Oil Shell Texaco Tri-Par Oil Co. U.S. Oil Hope this helps goodluck
08-22-2013, 03:09 PM | #11 | |
65
Rep 507
08-23-2013, 10:31 AM | #12 | |
1013
Rep 1,268
I like how this guy in the link above said his method works, but offers no proof, like pictures of the intake. He just said his performance was good and the dealer said it was the best running car he has seen. Like dealers do not lie much. I can tell you I had my intake cleans twice in 78K miles and other than the fact each time they cleaned the intakes they reset the engines adaptive learning which cause the engine to come to life again I did not see any performance difference before or after due to the intake being gunked up. Now, if I was racing and running the car on the edge of it performance I probably would notice the difference. In every day drives I did not see any decrease in its performance prior to cleaning. No odd behavior or lack of throttle response or anything similar. I would agree having all that carbon built up on the intake is not a good thing, you loose performance and gas mileage because of it. You also run the risk of possibly damaging the engine. Base on what I saw in my engine, and this obviously depend on your driving habits, it looks like they should be cleaned ever 25K to 30K miles. The reason I choose the walnut blasting is for two simple reasons. First it does the best possible job, better than any chemical clean I have seen so far and only takes about 40 minutes to do. Second, doing a chemical clean is not good for your engine. The Chemical dissolves or breaks down the carbon build up. So it caustic and could damage other things. Also if you let the chemical and carbon mixture go through the engine while running it what do you think this is doing to the cylinder walls and such. Why would you let chunks of carbons go into the combustion chamber. This like running your car without an air cleaner. I have rebuilt engines in the past and I seen the damage caused by not making sure you have nothing but clean fluid (air, gas, oil and water) running through the engine. This is why I could not understand what people would try and break up carbon and then allow it to go into the cylinders it just seems like an all round bad idea. Last edited by Maestro; 08-23-2013 at 01:01 PM.. |
08-23-2013, 11:09 AM | #13 | |
65
Rep 507
You are totally spot on with this comment, it really depends how you drive it track it ECt. Since i had the walnut blasting i found this method to work for me, i don't track my car very often, but consider myself to drive aggressively most likely like many on the forum , the only surefire way of getting ride of the carbon is walnut blasting.
