F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
Extreme Powerhouse
      08-16-2013, 04:08 PM   #1
azwillnj
318
Drives: 2023 M340i xDrive
I coded some stuff in the Kombi box and triggered a check engine light somehow, the car is running fine. Is there a way with the ENET cable to to check the codes and clear them?
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      08-16-2013, 04:40 PM   #2
HFW003
HFW003's Avatar
Australia
5697
Drives: 2024 M340i xdrive
You can try Tool32 and with thanks to Shawnsheridan, this is how you do it.
There are two versions of Tool32 in EDIABAS so make sure you use the German version as the English one won't work.
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
Good luck
H
      08-16-2013, 09:03 PM   #3
azwillnj
318
That worked perfectly, thanks so much!
2) Hit F3
5) Hit F5
Good luck
H
WE ARE!
      08-16-2013, 09:06 PM   #4
HFW003
HFW003's Avatar
Australia
5697
You're welcome!
      08-17-2013, 11:52 AM   #5
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
Let's chat about this a bit further as I was wondering the same thing.
Recently I had a bad experience after changing my spark plugs. The car was in limp mode, CEL on, and it would not start at all. There were TONS of codes stored when the car got to the dealer.
But I ran Tool32, all of the steps described above, and it did not find ANY codes. Thoughts?
      08-17-2013, 08:10 PM   #6
shawnsheridan
General
shawnsheridan's Avatar
10445
Drives: 2018 Alpina B6 650ix GC
2) Hit F3
5) Hit F5
Good luck
H
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      09-08-2013, 08:07 PM   #7
rdubmd
Drives: 2013 335xi M-Sport PPK
When I try to load the prg file the program just hangs... and if I click stuff I get different errors of OCX files missing, but they are in the folder... any thoughts?
Thanks,
2) Hit F3
5) Hit F5
Good luck
H
      09-08-2013, 08:30 PM   #8
shawnsheridan
General
10445
Thanks,
Is your EDIABIS.ini file set for ENET Interface?
Are you connected to the car, with power on the car when you try it?
      09-08-2013, 08:42 PM   #9
HFW003
HFW003's Avatar
Australia
5697
Thanks,
You need to use the German version not the one in English!
H
      12-19-2013, 08:51 AM   #10
navy.doc
Puerto Rico
Drives: 2014 335i M-Sport
I'm trying to use Tool32, but I think I have the English version, not the german how i can get the german version. Thanks
ED 2014 335i M-Sport AW - Sport Automatic, 403M, M Sport Brakes, NBT, Hupper Optik - 40% Tint, M Performance Black Kidney Grille, Rear Spoiler and Front Lip
Coming Soon: Borla Cat-Back S-Type
      12-19-2013, 01:43 PM   #11
HFW003
HFW003's Avatar
Australia
5697
If you, like many other, have received the coding package from Shawn then it is in there. You just need to search for it.
      12-20-2013, 02:00 PM   #12
navy.doc
Puerto Rico
Thanks,
What worked for me after reading for a while is to copy to C:\Windows\SysWOW64 the following files "MSLFXGRD.OCX" and "Richtx32.ocx" from C:\EDIABAS\Bin and register the using Command Prompt as an Administrator with the following command regsvr32 C:\Windows\SysWOW64\MSLFXGRD.OCX and regsvr32 C:\Windows\SysWOW64\Richtx32.ocx. I think this problem only happens in computer running 64bits. Hope that helps
Appreciate 2
Carl570.00
B58 parts477.00
      01-14-2014, 02:17 AM   #13
vitchie
vitchie's Avatar
32
Drives: 2013 F30 328i
Hi guys, I got the coding pack, but not sure where the german version of tool 32 is? There is only 1 tool32 in bin?
      01-14-2014, 03:07 AM   #14
HFW003
HFW003's Avatar
Australia
5697
I'm not sure what Shawn now sends out mate. Just try the one and see if it works. If it's not the correct one you will notice it just hangs when you try to use it.
      01-14-2014, 03:17 AM   #15
vitchie
vitchie's Avatar
32
Ok, figured it out. Had to run it as administrator.
      01-14-2014, 09:42 PM   #16
joeaye
joeaye's Avatar
Drives: '17 F25
I had the same issue with Tool32, I needed to run it on windows pro because it was 32bit and my machine only ran 64bit (or windows xp/vista). I tested this on a few computers too and that was the common denominator.
      01-15-2014, 12:59 AM   #17
steddyman
40
Drives: BMW F30 330D M-Sport Auto
I found when VO coding the KOMBI it reset the date and time. This causes the warning triangle to appear and setting it correct on the iDrive clears it.
      03-21-2014, 06:30 PM   #18
nyc_king
Drives: 2013 328i xDrive M Sport
2) Hit F3
5) Hit F5
Good luck
H
Hi, So this happened to me as well but I am running E-sys 3.24.3 and there is no EDIABAS folder. Is there another way to clear this with E-Sys?
      03-21-2014, 11:06 PM   #19
shawnsheridan
General
10445
EDIABAS is no longer included in E-Sys package as it is not required by E-Sys.
PM sent.
      03-29-2014, 03:12 PM   #20
BooGooBird
BooGooBird
BooGooBird's Avatar
17
Drives: 2012 BMW F30 335i
PM sent.
Can I also get the link for EDIABAS? Just got check engine light on after coded disable LED bulb check...
Thanks Shawn
      03-29-2014, 04:18 PM   #21
shawnsheridan
General
10445
Thanks Shawn
PM sent.
Largo5.00
      06-02-2014, 03:55 PM   #22
F30_NY91
F30_NY91's Avatar
Drives: 2021 C43 AMG
Hi Shawn
I have an engine code also. Do you have the latest tool32?
2021 C43 AMG, 2009 E350, 2016 Audi A6 3.0T (Sold), 2014 BMW 528i///M-Sport (Sold), 2016 BMW 340i///M-Sport (Sold), 2014 BMW 335i///M-Sport (Sold), 2006 E60 530i (Sold), 2001 E46 330i
f30post
