Subs using High end vs. Low end amps
08-15-2013, 02:28 PM | #1 |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Hi, quick question about using high vs. low quality amps to power a sub.
I know that a sub and amp should be matched as closely as possible by looking at RMS Wattage the amp gives, and the sub can handle. However, I also know that good quality amps are more efficient at producing louder volumes than low-end amps, despite having the same wattage rating (a JL amp rated at 500W will pound much more than a Thump amp 500W). If I have a 500W sub, which will be well suited for a 500W JL amp, will it handle 700W from Thump (theoretically) to obtain similar volumes, given that the Thump is less efficient at creating volume from Watts? Hope my question is clear. Thanks for the help! |
08-15-2013, 02:38 PM | #2 |
223
Rep 5,120
500watts rms is the same regardless of what amp it is. There are differences between different quality amps like efficiency and dampening factor.
The problem is quite a few low quality audio companies overrate their equipment and usually list max wattage which is usually some made up number that the amp will never produce. Your sub can handle any size of amp as long as your gains are set properly. |
08-15-2013, 02:43 PM | #3 |
379
Rep 2,365
What if the low-Q amp is rated at 500w RMS, just like the high-Q amp? Even though both ratings are the same (RMS), the high-Q will still produce higher volumes (likely from efficiency and dampening factors you mentioned).
If this is the case, does that mean a 600W RMS low-Q amp can damage a sub (at peak volume), even though it produces less volume than a 500W RMS high-Q amp? |
08-15-2013, 02:56 PM | #4 | |
223
Rep 5,120
You can power any subwoofer with any amp as long as the impedance isn't too low and your gains are set properly. |
08-15-2013, 03:00 PM | #5 |
379
Rep 2,365
Thanks, very helpful!
08-15-2013, 03:16 PM | #6 |
1911
Rep 13,104
It doesn't mean they will sound the same.
Power is only a one dimensional measurement. There are bunch of other specs like distortion at a particular frequency. slew rates and other stuff. |
08-15-2013, 03:32 PM | #7 |
223
Rep 5,120
Sure the sound quality might not be the same. RMS ratings are usually measured at a certain amount of distortion, especially if the amp is cea 2006 compliant. Usually if a company isn't cea 2006 compliant you usually shouldn't trust their ratings anyways. The frequency it is measured at does make a difference since amps don't put out as much power at lower frequencies. If an amp isn't cea 2006 compliant there is just no way to know how they got the number they got.
08-16-2013, 05:30 AM | #8 |
886
Rep 9,097
One example is
Alpine PDX 1.1000 = produced hardly 1000W. Max clip free was approx 950W. Jl Xd 1000/1 = produced around 1250W clip free sound. My 12W7 worked way better with JL Xd 1000/1 than alpine PDX.1.1000.
08-16-2013, 10:41 AM | #9 |
1911
Rep 13,104
Marketing always trys to make the specs look better.
That's why they always quote peak power and no distortion specs in mass marketed crap. There are a few good company's that are actually conservative about there specs better to stick with them if you want a quality trouble free product. |
08-16-2013, 11:05 AM | #10 |
69
Rep 994
not likely that you'd ever push your amp at max RMS wattage anyway. just buy the highest quality amp you can afford. you will have it for a long time and it will give you years of enjoyment and have a higher re-sale value.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
08-16-2013, 11:13 AM | #11 | |
223
Rep 5,120
Rockford Fosgate really underrates their amps. A 1500 watt amp will produce close to or over 2000 watts. A 2500 will do 3000 easily. |
08-16-2013, 11:19 AM | #12 | |
69
Rep 994
provided the electrical system can actually handle it. you're not going to see 2000 watts. that would be full output of a 140amp alternator at 13.8V. you'd be lucky to be close to that at 7,000 rpm. people need to stop harping over wattage and focus on the install. hell, proper sound deadening can give you the equivalent to adding more powerful amps just by silencing noise.
08-16-2013, 11:33 AM | #13 | |
223
Rep 5,120
The stock alt is 185 amps who knows what rpm's it produces that at though. Music is very dynamic and with enough batteries they'll be able to handle the peaks in the music and recharge on the not so bass heavy parts of the song. I'm using close to 3kw on the stock electrical with just an xs power battery. Although I could use at least 1 more battery just to be safe. It sucks that nobody makes a high output alternator for our cars. I've been looking for one of those since I got the car. |
08-16-2013, 11:36 AM | #14 | |
69
Rep 994
i agree, with A LOT OF WORK, it could be done lol, but most people just wanna throw thousands of watts in and think they'll actually achieve rated output with a stock electrical system. =) plus, you won't see 185 amps at 13.8V until you're high revving. you won't be cruising at 2k rpm and getting extreme output.
08-16-2013, 02:29 PM | #15 |
379
Rep 2,365
Thanks for all the info... personally, I was just asking hypothetically. I already have 2 Fostgate Punch amps installed in the car, but they're both 2 channels and I need to add more channels to the car. I have a handful of idle amps from cars passed, and was just trying to figure out what might work best.
In the end, I think my setup will look like this: Sony 4x75 - front doors and rear deck Punch 2x100 - underseat Punch 2x150 - bridged to mono sub enclosure in trunk I have other amps as well as access to some quality, but really old amps (HiFonics Zues and Jupiter amps), but I think I'll stick with the newer stuff... probably a bit more efficient on power consumption. |
08-17-2013, 07:47 AM | #16 |
69
Rep 994
Sounds good
