Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Should I do a coolant flush? 75k miles..
      08-12-2013, 08:09 AM   #1
miringrains
72
Drives: '11.5 M3 E93
I'm considering it, although I have a small coolant leak somewhere (need to top off every month)
      08-12-2013, 08:15 AM   #2
DRock3d
Kraut Driver
DRock3d's Avatar
59
Drives: 2014 650i GC/2011 335is DCT
2014 650i Gran Coupe  [0.00]
2011 335is  [1.00]
2007 328i  [2.00]
My water pump went, seemed like the perfect time to get that done lol
      08-12-2013, 08:55 AM   #3
Perceval
Perceval's Avatar
Drives: 325i e90
Hi Sir . Yes you should flush every year your coolant. Not the big flushing thing but only open the blue nut under your radiator. This way you will have to change approximatly 70 percent of your fluid. It is good because your coolant lost gradually his properties and became more acid. It cost approximatly 20 dollars.
      08-12-2013, 09:46 AM   #4
smallseafishie
110
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
A gallon of BMW coolant is approximately $20 alone.... not including labor or the distilled water for the mix.
      08-12-2013, 10:10 AM   #5
bhmax16
164
Drives: '22 M4, '23 CX-50
Flushing every year is a bit excessive. Every 3-4 years for coolant is more than sufficient. I do recommend testing with one of the suction type coolant testers every year though, just to monitor the freeze protection. Also change if it appears dirty or if your oil housing gasket is leaking (you will have plenty of rubber particles in your coolant). I believe they are one of the culprits that leads to premature water pump failure in these cars. I have 82k and still on my original pump
      08-12-2013, 10:11 AM   #6
dcat151
Wales
21
Drives: 2006 330i 6MT ZSP/ZPP/ZCW
Every year might be a bit much. I think Mike Miller recommends flushing the coolant every two years. It's not too difficult to do it yourself.
2006 Lotus Elise
2006 330i 6MT ZSP/ZPP/ZCW: Euro Air Intake, BMW Performance Exhaust, BMW Performance Strut Tower Brace, M3 upper and lower control arms, Euro Rear Fog Lights, G2 Caliper Paint
      08-12-2013, 10:19 AM   #7
mlifxs
Diamond Geezer
mlifxs's Avatar
212
Drives: Jet Black 2007 328i Saloon
i did mine at 100k, at year 6. Still on original pump and thermostat. if you want to do early, check out the DIY, not hard at all
      08-12-2013, 10:30 AM   #8
Monster900
Zeed
Monster900's Avatar
17
Drives: E92 335i
]Every two years is a good idea, that"s what I do.
      08-12-2013, 10:38 AM   #9
Gizm0
Gizm0's Avatar
426
Drives: 08 e92 335i 6mt
I did a coolant flush at 75k, and noticed a pretty significant improvement. Oil temperature decreased by an average of 15 to 20°F
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch
      08-12-2013, 11:38 AM   #10
PichaDis11
PichaDis11's Avatar
295
Drives: E90 N52
I would advise you to get the leak fixed before it gets worst. Then do the flush.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
