Turning off ONLY top corner amber light
08-10-2013, 12:27 AM | #1 |
92
Rep 709
Hello all,
I was wondering if there is any way to code out ONLY that tiny amber LED in the top corner of the headlight? To clarify, I would like to keep the default setting in which the turn signals are constantly on (changed them to white LEDs) when the headlights are on, but turn off the amber LED in the top corner of the headlight. I am attempting to do this for my E92 335i, 06/2007. Thanks in advance. |
08-10-2013, 07:46 AM | #3 |
Rep 116
08-10-2013, 03:17 PM | #4 | |
92
Rep 709
Modded, I look these up before going ahead with the coding, and it seems like they all do the same thing. Is it necessary to code all of these? Do you know what they each do individually? I have just began coding (got my v= ) and I'm just trying to be cautious with what I change and how I do so. Thanks very much. |
08-10-2013, 07:49 PM | #6 |
92
Rep 709
08-12-2013, 07:03 AM | #7 |
92
Rep 709
03-08-2014, 05:46 AM | #9 |
Rep 116
03-08-2014, 10:35 AM | #11 |
Zeed
17
Rep 561
03-08-2014, 03:16 PM | #12 |
92
Rep 709
03-08-2014, 03:35 PM | #13 | |
Zeed
17
Rep 561
SL_V_PO_RL_FKT nicht_aktiv PWM_SL_V_BEI_AKTIVEN_AL wert_04 PWM_SL_V_BEI_AKTIVEN_FL wert_04 |
03-08-2014, 05:25 PM | #14 | |
92
Rep 709
If I remember correctly, I believe what did it for me was going into NFRM and changing SIDEMARKER_US from aktiv to nicht_aktiv.
03-09-2014, 05:38 AM | #17 |
Boooost!
70
Rep 793
Drives: 335i
I'm trying to turn off the top led on my headlights as well. Does the coding above work while selecting the CAS ecu and then using function to load PSW FSW man and then to execute or is this done differently?
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
03-09-2014, 10:56 AM | #18 | |
92
Rep 709
I would imagine it to be the same though... |
