Changing the cruise control speed display from mph to km/h
08-09-2013, 03:50 PM | #1 |
12
Rep 214
Drives: 2009 BMW 335i Coupe
Hi all,
I searched but found only one thread on here relating to this issue without a confirmed answer. Anyone know which module I would need to code (and which values) to change the cruise control display from mph to km/h? I have a 2009 E92. Thanks! |
08-10-2013, 04:42 PM | #6 |
12
Rep 214
I did switch the settings in the idrive to km instead of mls but the cruise control speed still displays in mph.
I'll check those values in the DSC module and report back, thanks charles.soori! |
08-10-2013, 04:44 PM | #7 |
12
Rep 214
The cruise control speed is displayed for me when i initially start the cruise control or if I change the speed in the first small screen at the top (where the temperature and time is displayed).
08-10-2013, 05:34 PM | #9 |
12
Rep 214
08-10-2013, 06:32 PM | #11 |
12
Rep 214
08-24-2013, 01:49 PM | #12 |
10995
Rep 32,881
Well i found that i had to code to get the cruise control speed display.
For anyone who needs to do this it's KOMBI TEMPOMAT_SETZ_ANZ_DAUER Change from wert_1 to wert_2 It also has made the car actually stay at the speed i pull the lever at, it used to set it about 2-3 mph less than when i pulled it! |
08-26-2013, 04:57 PM | #13 | |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-23-2015, 02:09 PM | #14 |
Rep 5
I changed this two parameters, but when i tried to activated cc i had only yellow course control failure light. In miles everything works fine. Anybody know what next i should change to have course control in km ?
08-24-2015, 11:22 PM | #15 |
17
Rep 62
09-15-2016, 11:04 PM | #16 | |
749
Rep 2,108
I have an F80 and want to do the same change to my car. I looked for those parameters in my DSC module hoping it would be the same as the E9X series but unfortunately couldn't find them. Any idea what coding needs to be done for the F80 or F-series generally?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
09-17-2016, 12:47 PM | #17 | ||
23
Rep 265
09-18-2016, 10:11 PM | #18 |
749
Rep 2,108
Yes ofcourse, that was the first thing I did. I also did some coding in the KOMBI, NBT, and ICM modules. Everything has changed from MPH to KM/H except for the cruise control speed setting displayed on the instrument cluster. Even coding for a KM/H kombi unit being installed didn't do the trick.
01-16-2017, 04:31 PM | #19 |
73
Rep 199
So I have a weird one guys. Did a M cluster conversion and everything displays MPG as wanted except for one stupid place... In iDrive/Settings/Speed my Speed warning is displayed in km/h. It is not a big deal but just checking if anyone had a clue. I already tried changing Language/Units back to km and it changes the cluster and then change it back to miles but it has no change on the speed warning. Thanks for the help!
01-16-2017, 09:23 PM | #20 |
Rep 33
I just tried this tonight but for some reason my car isn't reporting a DSC module. It shows the BDSC module which doesn't appear to be related. This is on a 2009 E90 (335i). I have coded several other parameters in various modules so I don't think the problem is user error (but I'm still learning so I could be wrong).
The dump file created when NCS expert starts does include entries for C0C_V_EINHEIT and C0C_SETZ_V_MAX though. Any idea how to find out what the module name is from the FSW_PSW.TRC file? |
