BMW Professional Head Unit
08-08-2013, 09:04 PM | #1 |
35
Rep 1,691
I had my original head unit on my 07 328 replaced due to dead pixels. The company that replaces them put in a refurbished one. Now my Bluetooth doesn't work. Is this a coding issue or a head unit issue?
Thanks.
2007 BMW 328I Monaco Blue /// 1999 BMW M3 Titanium Silver /// 2007 BMW 328I Sparkling Graphite (sold)
08-09-2013, 12:49 AM | #2 |
1911
Rep 13,104
Most likely it is.
This is what my rad file looks like with Hi Fi , bluetooth and SOS.
CODIERUNG_ERFOLGT codierung_erfolgt CDC nicht_aktiv AUDIO_SYSTEM pl2_hifi pl3_hifi SDARS nicht_aktiv PDC nicht_aktiv ACC nicht_aktiv STANDHEIZUNG nicht_aktiv AUX_RAD aux BAUREIHEX e9x COUNTRYCODE_RADIO us IBOC nicht_aktiv KEY_MEMORY_R aktiv MUTE_TIMES pl2 NACHLAUF_INT_R pl2 RIGHTHAND nicht_aktiv SOFTEN_ENTERTAINMENT_PDC nicht_aktiv TCU_ECE nicht_aktiv TIMEOUT_INT_R pl2 ULF_ECE nicht_aktiv BMW_AKD nicht_aktiv BMW_HOME_DEALER aktiv BMW_INITIALIZE aktiv BMW_MOBILE_SERVICE aktiv BMW_PHONE_SERVICES nicht_aktiv BMW_ROAMING nicht_aktiv BMW_TELESERVICE_ONLY nicht_aktiv RING_STATUS aktiv BLUETOOTH_RAD2 aktiv DISPLAY_LOGIC7 nicht_aktiv HI_TEMP_VOL_CTRL pl2_hifi pl3_hifi SMS_RAD2 nicht_aktiv PHONE_BUSINESS_R2 nicht_aktiv SVS_LOW_RAD2 aktiv BMW_ASSIST_RAD2 aktiv BMW_HOTLINE_RAD2 aktiv DAB nicht_aktiv CAR_COMP_ACTIVE aktiv TCU_JAP nicht_aktiv CONTACT_NR_DEALER aktiv CONTACT_NR_HOTLINE aktiv CONTACT_NR_MOBILE_SRVC aktiv ABS_VOL_GONG e91_hifi CROSSOVER pl2_hifi e90_hifi r56_stereo r56_hifi DELTA_GONG_ENT wert_0 DELTA_PDC_ENT wert_0 RATIO_AUDIO_SOURCES ece us VEHICLE_FILTERS e81_stereo e82_stereo e87_stereo e88_stereo e90_stereo e91_stereo e92_stereo e93_stereo pl2_hifi r56_hifi VOL_TEL_MAX stereo_mulf_e87 hifi_mulf_e87 top_hifi_mulf_e87 stereo_mulf_e90 hifi_mulf_e90 top_hifi_mulf_e90 stereo_mulf_e91 hifi_mulf_e91 top_hifi_mulf_e91 stereo_tcu hifi_tcu top_hifi_tcu VOL_TEL_MIN wert_0 VOLUME_TABLE e91_hifi MY_INFO_RAD2 nicht_aktiv V_INFO_RAD2 nicht_aktiv PHONE_PROF_RAD2 aktiv The coding resides in the Head Unit for these settings it acts as a sort of server or controller for the MOST Bus to which the TCU is connected. I thing the coding board could tell you best how to get the correct values back in the car . It is my understanding the values may be duplicated in other modules and you might only have to do a reset to get them to reinitialize or you might have to go back in and change the appropriate options back to activ from nicht activ and rewrite the file. Last edited by ctuna; 08-09-2013 at 01:05 AM.. |
08-09-2013, 01:03 AM | #3 |
35
Rep 1,691
Does this mean that every head unit has the Bluetooth functionality, it just needs to be activated via coding?
08-09-2013, 01:16 AM | #4 |
35
Rep 1,691
Thanks for the info ctuna
08-09-2013, 01:50 AM | #5 | |
886
Rep 9,097
Old HU connects to mulf / tcu. New HU has built in BT.
08-09-2013, 02:37 AM | #6 |
1911
Rep 13,104
Before about 09 bluetooth telelphone usb were hardware.
Before about 09 Bluetooth telephone usb were hardware modules
separate from the radio . Some where around 2011 they started integrating the hardware for some of these functions in the radio. If you have one of the older cars there are separate hardware modules. Also the hardware modules varied by year . This makes upgrading a more involved for things like ipod and usb for these years . See the bluetooth sticky at the top of the page it will make your head spin, with names like TCU , Mulf,Mulf2, ULF etc etc.. The follwing file describes the entertainment system as it was. http://www.e90post.com/forums/attach...2&d=1260829447 Read about the most bus in the following file http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf this a thread about the new head unit with usb , bluetooth integrated into the hardware. http://www.e90post.com/forums/showthread.php?t=687463 |
08-09-2013, 01:18 PM | #7 |
1911
Rep 13,104
Since the link to the electrical system isn't working
You can get it here along with a lot of other useful pdf's
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ but you will have to join the board I think. |
