Need help with Light that just popped up! Radio down!!
08-05-2013, 02:04 PM | #1 |
Rep 20
Ok.. everything was going fine up until i started my car last night and an SOS wit a phone and slash over it light came on, the manual says "SOS system is malfunctioning seek immediate service" but I dont even use it! N last night just to play with it after this all happened I pressed the button for the first time ever n to my surprise a operator answered but I dont think he heard me that well.. the Radio wont turn on.. its completely off. What do I do? And Ive researched this on the forums because its happened to others but diff people are sayin diff things plus using software lingo I dont get.. Im not car savy at all.. someone please help, I cant drive around jus hearing silence :-\ .. Thanks in advance
08-05-2013, 04:58 PM | #3 | |
555
Rep 1,244
Drives: 2013 F10 M5
Find someone with a diagnostic tool (INPA, DIS, ISTA, Autologic) and pull the codes from the car. It should tell you which device is causing all the problems. |
08-05-2013, 05:02 PM | #4 |
964
Rep 3,854
Drives: 330i, 135i
Check your fuses if not look for error codes. Go to your local auto zone store and have them hook up the code scanner. Should be free or buy the guy lunch or something...keep us posted.
08-05-2013, 06:16 PM | #5 |
Rep 20
Ok.. so I jus turned the car on (haven't since about 11pm last night) the service light pops up with an image of the vehicle.. but tht SOS light didnt come on n now th radio is working... honestly Im afraid to turn the car off for a short amount of time and turm it back on..cuz i heard thts usually wen problems show themselves .... anyway wat fuses can I check cuz Im already expecting this to happen again soon.. and I jus walk into autozone and ask for a diagnostic reading??
08-05-2013, 06:21 PM | #6 |
964
Rep 3,854
Drives: 330i, 135i
Dont take this personal but sounds like you are not mechanical inclined enough to do any troubleshooting . Go ahead and take it to a BMW Indy shop and let them take a look at it... Keep us posted. Good luck
08-06-2013, 04:08 AM | #7 |
Rep 20
Your %100 right.. wouldnt know wat to touch or how to touch it anyway so Ill jus leave that to the proffesionals.. My main concern is how much does something like this cost to fix? if it is what you guys are insinuating it is?? Because I just drove it again and the radio plays now n seems fine. I jus really want to know if someone has had this problem and taken care of it so I know the price range Im lookin at....
08-06-2013, 11:49 AM | #8 | |
555
Rep 1,244
Drives: 2013 F10 M5
Price to fix would depend on the module having the problems and the cost to replace that module. |
08-08-2013, 10:49 AM | #9 |
Rep 16
SOS malfunction/no bluetooth/no radio sound!
I too am having this issue- I did replace the fuses-didn't work. I have a 2006 bmw 330i. (I do not have a dvd-mute button to reset) are there any other combinations to try? I want to try disconnecting the battery or tcu module to see if I can reset that way-battery has 2 positive connects! I read I'm supposed to disconnect negative cable-some advice please on the battery cable?! In the tcu module what plug do I disconnect- I want to try all possible reboot solutions before bringing it into the stealership. Thanks.
08-08-2013, 10:59 AM | #10 |
964
Rep 3,854
Drives: 330i, 135i
Guys u should disconnect the negative terminal for about a minute from the battery. This will not do any harm. Its worth a try. Keep us posted.
08-08-2013, 12:41 PM | #11 |
164
Rep 401
Not sure why anybody is pointing you to fuses. Fuses don't cause intermittent issues (they're either blown or they're not). You have an issue with a wiring contact or a faulty module based on your explanation. Also, how is your battery? Batteries in these vehicles cause all kinds of electrical gremlins when they near the end of their useful life. Don't take the vehicle to autozone to have codes scanned. Their scanner can't pickup codes in this particular module. You need to use INPA or BT tool if you're not bringing it to an indy or dealer to draw the codes. From there we can help you determine what component is faulty
08-31-2013, 10:14 AM | #13 |
37
Rep 246
Hello: I have the same problem. Intermittent radio, no bluetooth, no chimes, can't charge the phone. Now the radio has completely stopped. In checking the TCU (In the trunk, just ahead of and above the battery), I disconnected the wiring, saw a bit of smoke, and some of the plastic on the connector appears burnt, and one pin is completely missing. I'll investigate further today, and maybe hot wire the failed pin. By the way, this is a 128i.
Jack |
