Musicar Base Stereo build in 2010 335d
08-04-2013, 01:13 PM | #1 |
289
Rep 3,201
It's been a long time since we've posted a build thread, and now that we have official dispensation to post build threads as a vendor (we just renewed our sponsorship vendor status, and there is vague language in the agreement, so we just recently were informed that we can post these!)
2010 335d, client lives in Portland. For those wondering (it's increasingly harder to find our three-year-old posts on the topic) the base stereo system is laid out like this: The signal to the rear speakers is high-passed (the bass is attenuated) the signal to the front doors and the underseats is full-range, but both signals have significant equalization: FRONT REAR So, the rear speakers are currently the best-sounding speakers in the car. That's because they don't "see" the lowest bass notes, so they distort the least when those notes happen. This roller-coast needs some correction before good speakers will sound good. It doesn't need a $1000 processor (we offer that level of performance, but it's not essential for an upgrade). It needs to be flattened out, and this system used the lowest-cost way to do that, the JL CL441. If you calibrate this wrong, the door chime will rip your head off. Our Base Stereo upgrade systems are available with Rear Speaker Retail or Rear Speaker Upgrade. This client selected the most common version, RSR. With this package, we use our Stereo PnP harness to "grab" the front channel outputs of the deck and the door speaker leads, and extend them to the trunk. We also incorporate dedicated speaker wires for the underseat woofers. Then we run the signal into the lowest-cost correcting processor on the market, the JL CL441dsp. (I know some people want to recode, we can discuss why we use this method later). In three-way, no-added-sub systems, that feeds the 4 channels of the Arc Audio KS125.4 Mini amplifier. It uses Class G, not Class D, and we think it sounds a bit better than Class D. The speakers vary. This customer got a Level Two system, with Morel front components and the Jehnert underseat woofers. We prep it all for BMW bolt-in, plug-in installation, as the pics below will show. Here's where the amp would have been in a HiFi or Top HiFi car: Here's where the optional Sat Tuners used to go: Here's the stock door speakers and stock underseat speakers: Here's the Musicar system as it would arrive to a customer outside our area (you buy the tweeter trims locally, too big to ship economically). The gray tray in the right front corner is the new trunk tray, which we do include, so that an amp will fit under it and the entire trunk will look stock. And here are some build pics: Stock speaker off: New speaker on: Crossover installed and PnP harness attached (we supply the gaffer's tape): New woofer bolted in place of stock speaker: Trunk before we started: Amp, premounted on plate, ready to insert speaker wires into (this is 99% of the wiring in the install): Where the processor goes: Attach the power harness to the battery: Route the signal harness from the processor to the amplifier following factory wiring: Finished install: Car sounded great. Blew away harman/kardon, better than Enhanced Premium, and it can ALL go back to stock in future if desired. |
08-04-2013, 01:14 PM | #2 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
very nice upgrade!
08-05-2013, 04:27 PM | #5 |
Rep 13
You mentioned you are "grabbing" the front channel outputs from the deck using your custom PnP harness, but I'm just curious as to exactly where the harness plugs in? Is the harness connected somewhere in the trunk, or is it somewhere up front and then routed through to the trunk and into the Cleansweep? Thanks for your help, just trying to get an idea of how difficult an install this would be if I ordered from you.
08-05-2013, 05:33 PM | #6 |
Rep 97
I'm interested. I just saw a M3 with your system installed last weekend in NJ. Awesome!
Please PM me with your packages and prices. I have a 2011 M3 sedan with the HIFI system. Dave
2011 M3 Sedan DCT ZCP, Dinan exhaust, Vorshlag Camber plates, aFe CAI, Girodisc Rotors, Hotchkis Sway bars, PFC and Ferodo brake pads
2014 Porsche Cayman S 2003 540i M-Sports Pkg, Dinan (retired) |
08-06-2013, 02:29 AM | #7 |
45
Rep 217
Ken, is there a good reason to always go the long way round with the power and ground cables? On the E91 it certainly looks like there's room to go behind the plastic panel at the back of the car. That plastic panel is a bitch to remove though so I may not be able to use the chassis ground bolt there like you can on the E90.
08-06-2013, 09:20 AM | #8 |
special
35
Rep 857
Are the rear deck speakers disabled or running off the head unit "amp" still?
Euro spec wide mirrors; sport wheel + paddles; staggered sport rims with Conti ExtremeContact DW. JL Audio 600/6 + technic harness; Gladen Audio 8" Woofers + musicarnw adapters; Morel Hybrid Ovations. |
08-06-2013, 10:18 AM | #9 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-06-2013, 11:16 AM | #10 |
45
Rep 217
08-06-2013, 11:33 AM | #11 |
36
Rep 138
Nice job! It looks really clean! Myself Im still in progress with a build in my 320D E90.
I am using the Gladen 200 BMW kit as front amplified by a DLS CA41 and before going to work I just made a quick install of a 12" sealed enclosure to see if it made any difference. The music just felt amazing compared to the base, I had just as you. Now when I'll get home next time I'll install a Mosconi 6to8 processor and make a better install for my sub. Im also wondering if its worth amplifying the rears, already changed to a pair of coaxials... Ofcourse after a signalsum trough my dsp :P |
08-06-2013, 01:18 PM | #12 |
1911
Rep 13,103
Hopefull see the email I sent yoiu e91 is not that bad
Hopefull see the email I sent you e91 is not that bad.
At first it looks like a nightmare but there is a way around taking everything off. http://www.e90post.com/forums/attach...3&d=1329017429 |
08-06-2013, 02:19 PM | #13 | |
45
Rep 217
08-06-2013, 06:25 PM | #14 |
289
Rep 3,201
As an e91 owner, I would much rather run the wires where the factory did than cut plastic tabs off and then run wires underneath. Kai, I'm surprised at you
Why does BMW go the long way round? Because that's where the room is. |
08-07-2013, 02:38 AM | #15 | |
45
Rep 217
Ken, as an E91 owner, which ground point did you use (as the one behind the panel is difficult to access)? |
08-07-2013, 02:32 PM | #16 |
289
Rep 3,201
We ALWAYS ground to the back side of the bumper, the other end of the ground cable from the battery terminal. Best place, and we never have noise issues.
This isn't a wagon, but it also gives you the best view of the bolt. |
08-07-2013, 03:51 PM | #17 | |
45
Rep 217
Sorry, I didn't mean to hijack this thread Just looking for a bit of advice from someone who's done this before (Ken) |
08-11-2013, 11:03 AM | #18 |
Rep 33
Wow looks great and I'm contemplating a level II. Is it optional to display the Morel badge on the speaker grilles? Not positive how I feel about that.
