noob philosophies about 335 exhaust
08-04-2013, 01:16 AM | #1 |
53
Rep 912
hi guys,
so i started my car today and was grabbing something out of the boot. realized that only 1 exhaust was actually blowing out air. Im going to take it that this is normal, but how can i have both exhaust working at both times? is this the golf t mod / dc the cable in the boot thing? thanks |
08-04-2013, 01:21 AM | #2 |
324
Rep 2,014
Yes, that is the golf tee mod. I did the actuator unplug method and it makes the car sound a lot better IMO
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
08-04-2013, 01:29 AM | #4 |
I have to return some video tapes
362
Rep 4,712
You can unplug the actuator, which is easiest. Doesn't matter if the car is on or off. Open the boot, go into the left compartment and unplug the only wire you can. It's very easy and quick. Makes the exhaust sound better and air comes out of both sides
The reason you only felt air out of one side is because there is a valve that closes unless you are at a certain rpm or throttle level. Unplugging this wire turns this feature off
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
08-04-2013, 01:31 AM | #5 |
53
Rep 912
i was reading on the diy but i just couldn't get my head around it 100%. ESL for life!!! haha
ill get on it asap. come at me grunt!!! love it when she grunts at me |
08-04-2013, 04:27 AM | #6 | |
72
Rep 436
WTF... |
08-04-2013, 08:30 AM | #8 |
60
Rep 1,024
If you end up throwing a tune on the car, they can control it too. I know JB4 has an option for the valve to always stay open, assuming others do too. In the meanwhile, pulling the cable works
08-04-2013, 08:33 AM | #9 |
53
Rep 912
yeah but then i have to run on the jb all the time. i only use the jb when i have to.
08-04-2013, 08:44 AM | #11 |
60
Rep 1,024
I run map 5 full time. There's no need to toggle it when needed, it's safe to leave it on
08-04-2013, 10:52 AM | #13 |
56
Rep 1,464
Drives: 2009 BMW 335xi
Stock boost peak is ~8.8 psi.
08-04-2013, 12:43 PM | #14 |
26
Rep 606
Opening the valve will increase drone too which is why I keep mine closed. Using a JB4 doesn't decrease gas mileage. You can avoid using the turbos all together pretty easily if you're careful on the throttle.
