08-02-2013, 04:19 PM | #1 |
22
Rep 117
Firewall Access?
Anyone have any success finding firewall access from the engine compartment to the passenger compartment?
Want to plan out how to route cables for a STI-R or 9500ic or Laser Interceptor. Thanks! |
09-09-2013, 09:43 PM | #2 |
Rep 21
Bumping this as I too am interested.
09-13-2013, 09:45 AM | #3 |
35
Rep 214
I need the answer too. Gonna install a 9500ic soon and don't want to pay ridiculous installation costs for an easy job.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
09-13-2013, 06:19 PM | #4 |
BimmerPost Supporting Vendor
171
Rep 1,397
if you take the cover for the positive terminal off it'll expose the fuse box area, if you look at the bottom left corner theres a couple of rubber sealed holes.
Cut a littl eslit in one and you can push a wire through and it'll come out behind the passenger glove box |
09-13-2013, 08:08 PM | #5 | |
Rep 21
How do you get the wires OUT of the fusebox?
I wonder if the F30 3 series has the same unused rubber nipple under the steering column area/wires as the E90 did. That made wire runs very, very easy. Cut a small slit and pass through as needed. |
09-25-2013, 05:19 PM | #6 |
195
Rep 467
I'm going to look for this later. Hoping I can route the JB4 cable through it like I could on the E92
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone 2018 M4 ZCP: current 2023 X3M Comp: current |
09-25-2013, 08:11 PM | #7 |
Rep 21
Thanks, please keep us posted.
10-12-2013, 09:33 AM | #9 |
32
Rep 12
Sure, you can find pics and info on my post about PDC Retrofit: http://www.f30post.com/forums/showthread.php?t=869735
10-13-2013, 11:14 PM | #10 | |
Rep 21
Looks interesting- but what happened to under the steering wheel access?
Never would have thought it possible to route as you did. I wonder if such will work on US based cars. Thanks! I'm still a but confused (my F30 335xi is on order), but will check when it eventually shows up. On the E90 ther was a rubber like "nipple" under the steering wheel by the main harness entry. Made life easy. I wonder if the F30 has such as well. |
10-20-2013, 02:47 PM | #11 |
42
Rep 16
I wrote a DIY for the retrofit of a DEFA WarmUp interior heater (Termini 2100).
It's in German, but well illustrated. I used a pull-wire to route the cable through the firewall. |
10-20-2013, 03:43 PM | #12 | |
Rep 21
Helpful & well written, but I have a question
Does the entire glove compartment need to come out to run the wire? Or, was this needed to install your heater? Thanks! |
10-20-2013, 06:13 PM | #13 | |
42
Rep 16
Then pull the wire together with the cable into the engine compartment. In my case it is a cable of approx. 15mm diameter. So, the removal of the glovebox was helpful. |
10-20-2013, 06:22 PM | #14 | |
Rep 21
Thanks, very helpful
Even though your write up was in German I used a translator, which helped quite a bit. |
12-21-2013, 01:35 PM | #15 |
Rep 21
This grommet worked!!
Just got a 2014 335xi & followed this thread for firewall access:
http://www.f30post.com/forums/showth...light=firewall My 335 does NOT look the same- I have a rain funnel or the like not shown in these pics. However, I can confirm that the rightmost grommet (has a smaller arrow and closest to the fusebox) in the pic did work, although I needed a stiff and narrow fish tape. I used a heavy duty 3' long cable tie, which was initially too wide so I carefully cut it in half with a utility knife. NOTE: The pic below is from the link above. It is NOT my car. Better still, there is a switched 12v power source on the lower dash cover I removed. Its the plug under the passenger footwell. I'll finish the Laser Interceptor another day. Looks like rain is heading my way. Last edited by jws360; 12-21-2013 at 03:17 PM.. |
