Took the 335i back to the dyno today...
08-01-2013, 11:54 AM | #1 |
1693
Rep 3,289
It's taken about 12 months, but finally all the mods on the car is done. Took it back to the dyno today so see the results (hottest of the day of the year)…
Last year, running a JB+ box (set at 50%), and Forge intercooler with Tesco super unleaded (99 Ron), 15 degrees ambient temp, the car made 316bhp at the crank. Now running, AFE sealed intake, AR catted downpipes, Forge intercooler and Procede tune with boost limit set a 14 PSI, Tesco super unleaded (99Ron), about 29 degrees ambient temp, the car made 380 bhp and 390 lbs at the crank. Total spend is hard to workout because the labour on the downpipes were part of a larger install, but about £1800 in parts. Had it been cooler, or had I pushed up the boost limit to 15-16 psi am sure the car would have made more bhp, but as it is, I'm very happy!! Whilst speaking to the garage owner today he quoted me labour £800 for new turbos….which i thought was alright, who knows, RB turbos might be the next aim Last edited by gangzoom; 08-01-2013 at 12:10 PM.. |
08-01-2013, 12:03 PM | #2 |
Senior Troll
224
Rep 3,378
No intercooler???
Add an IC , you probably will see 400 i guess? I will do mine once i get my New ETS fitted with second cat delete with Panel filter and Cobb
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
08-01-2013, 12:09 PM | #3 |
1693
Rep 3,289
08-01-2013, 12:35 PM | #4 |
Rep 77
Drives: E92
Why do you have a power and torque spike after 2600 rpm till 3800 rpm? It seems like it makes less power, then more again sharply, is that right or did you get wheel spin
35iS, Black/Coral Red, 19" BBS CH-R/MPSS, Eibach Pro Springs, Golf T, Stubby, LED 80w halo's, X6 tips, CarPro CQuartz, Custom painted accessories
08-01-2013, 12:41 PM | #6 |
37
Rep 519
390lbs of torque That must be fun.
I don't know alot about the shape of dyno graphs but mine shows much more linear power delivery. Your boost looks like it kicks in ferking hard. I bet it a handful but fun. Here's mine. Only mod is a JB4. |
08-01-2013, 12:42 PM | #7 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
I heard only rubbish things about Forge. Their end tank design is not very good.
You have low power... yes it is a hot day, but people in the states make 400 all day long. Upgrade the intercooler |
08-01-2013, 01:30 PM | #8 |
15
Rep 791
The forge cooler is too notch. Ill get a pic up of one thats been cut at the tanks to show the design. Trust me they are pretty damn good. Not sure who waffled the bad end tanks story to you but its certainly not true. I know john and chris at forge very well indeed and every part made is flow tested. If it came out wrong or crap it qould be binned and redesigned. Trust me iv whitnessed it time and time again.
08-01-2013, 01:49 PM | #9 |
1693
Rep 3,289
Looking at the dyno graph again, I can only presume it's wheel spin, wasn't there for the runs, had to be at work today, but day to day driving there certainly isn't any noticeable turbo lag.
Regarding peak power, I'm not sure what peak PSI the Procede tune aims for normally but I'm pretty sure if I had put the boost limit up above 14PSI it would have hit 400 quite easily but I rather run the car day to day on a lower boost target, and 380bhp is hardly a 'low' output . Pretty happy with the car, the only other upgrade I'm seriously considering is RB turbos for when the OEM turbos eventually go. In sort the N54 unit in the 335i is great . |
08-01-2013, 03:55 PM | #10 |
10
Rep 172
weres all the low end power, that graphs horrible, yes nice top end figures but all your bottom ends gone....do you really have no boost till 3800 rpm's?
08-01-2013, 04:17 PM | #11 |
Senior Troll
224
Rep 3,378
I am also not sure why you slagging it so much. I had it and sold it..the forge was really good but the pipework is such a pain.. Not idea when i constantly need it on n off hence the reason i went for ets
Gone:
08-01-2013, 04:56 PM | #12 |
170
Rep 3,828
I am just going from hear say. The man i spoke to at Uxbridge who has built one of the most thought out 135i's in the country had trashed them after his setup was limited terribly by his Forge. He showed me his dyno graphs and it was pretty obvious.
The turbulance caused when the air rushed through the intercooler resulted in higher temps as the turbos were forced to work harder and lost 19bhp on his current UK intercooler setup, for which i cannot remember the name. He has a dark red 135i which has been converted to almost a 1m rep... Know it? |
08-02-2013, 02:17 AM | #13 |
112
Rep 2,621
Looks like the guy who did the dyno doesn't have a clue! Did they just do one run?
What gear was this? The power seems a little low for your mods, but then again stock cars with no other mods get similar power at 14psi.
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
08-02-2013, 02:56 AM | #14 | |
1693
Rep 3,289
I'm pretty sure the car can easily make more bhp, but for me 380 is more than enough, infact most of the time I have the boost limit set at 10.5 psi which is hardly above stock, which i guess would be 320ish bhp max. Touchwood the car has been faultless since my ownership, so rather run conservative power than push things too far. But that's me done on mods now, saving up for RB turbos though, am sure at some point my OEM turbos will need replacing . |
08-02-2013, 04:46 AM | #15 |
67
Rep 1,431
So you're contemplating RB's for an extra 40-50 bhp? A proper tune and set up could see your car as it is now running that kinda power.
You're right 380 is plenty but why settle for that when more is available, and for free! WM |
08-02-2013, 04:53 AM | #16 | |
Rep 77
Drives: E92
Additional wear and tear on the drive chain, clutch, drive shafts, tyres, turbos, oil, etc etc etc.
08-02-2013, 04:54 AM | #17 |
112
Rep 2,621
RBs would compound those issues much more.
08-02-2013, 04:57 AM | #18 |
1693
Rep 3,289
Just to reassure my self, had another look at my logged runs, and am pretty sure the guy doing the dyno must have had wheel spin at 3000-4000 rpm, since on my logged runs by 4000 rpm the boost is already nearly at 14 psi!! Looking at other N54 dynos graphs it appears maximum torque is usually around 4000 rpm, wheres on my graph at 4000 rpm the car is making hardly any torque/power, so wheel spin seems like the most feasible explanation . So I guess the maxium torque is probably over 400 ft-ibs
Not chasing big BHPs, but when the turbos go (which they will at somepoint) I might as well get them replaced with some better non-OEM ones...I know all I have to do is up the maximum boost limit and the Procede Tune will easily push out more BHP for the engine, but I rather get more BHP from upgrading the mechanical bits, it makes no sense at all I know, but if I have any sense regarding £££ and cars I'll be driving around in a 1.0 Micra Last edited by gangzoom; 08-02-2013 at 05:04 AM.. |
08-02-2013, 05:08 AM | #19 |
1693
Rep 3,289
08-02-2013, 08:58 AM | #20 |
32
Rep 1,271
Drives: 335i (sadly gone)
+1 for the wheel spin and weird power curve. This is mine when on just an Evolve stage 1 and shows similar numbers to you but more torque and linear delivery:
08-02-2013, 09:50 AM | #21 |
76
Rep 1,518
08-02-2013, 10:05 AM | #22 |
1693
Rep 3,289
Cheers for your graph idnan, not sure why mine looks weird the dyno graph from 12 months ago was perfectly linear, and to drive the car certainly doesn't feel its lacking in power at 3Krpm, quite the opposite 3Krpm is usually where the car really starts to pull.
Next time I take the car in for a service I'll ask them about it, but for now I'm not too bothered. Still amazes me how much tuning potential there is in these N54 units!! |
