aux interference whine sound.
08-01-2013, 05:04 AM | #1 |
Rep 75
Drives: 10' bmw 335i
I have a 09 335i with hd radio. For some reason when I use the aux input I get what sounds like interface or a whineing sound.
Anyone have the same issues? The car is cpo but I am aware it does not cover the radio but idk what category that would fall in. I purchased the car from bmw about 30 hours ago. Im going to call them tomorrow morning. |
08-01-2013, 11:49 AM | #2 |
69
Rep 1,766
Do you have your smartphone (which I'm assuming is your audio device) at max volume? That's what happened with mine (same results with the USB port) so I keep the iPhone at half volume and blast the car's stereo volume.
Oh and get a Blackberry Music Gateway. So much better than using the aux port.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
08-01-2013, 12:02 PM | #3 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Is your phone plugged into the power as well? Whines are usually ground faults but since a phone is "floating" it shouldnt' cause any issues unless there is another ground path (like a phone charger).
08-01-2013, 12:02 PM | #4 | |
Captain Dutch Rudder
204
Rep 2,258
And an interesting note, When i turn my iphone volume full blast, the humming noise goes away in my car, but there is still a slight hum.
No more E92 or E82
08-01-2013, 12:04 PM | #5 |
Rep 112
Your issue is caused by impedance. It is basically the static noise that you are receiving. The reason for the sound is do to not enough power in the aux input. I have brought this up to BMW a couple times, and they do not have a solution. However, there is a way to fix the problem. If you buy a portable amplifier ($50-150) it will solve the power issue which is causing the noise. Audio device to amp and amp to aux port in car. It will give enough power to play your music. Companies like Fiio works really well.
The other solution is a usb stick (not all are compatible). I found the best results is to get a microsd card, and a reader which has a standard usb port attached to it. Aux will only give you 2.1 audio which is all it is rated for however, music through usb will let you use the full potential of your stereo system; resulting in "cd quality music" 128kbps and up. |
08-01-2013, 12:11 PM | #6 |
157
Rep 637
Drives: e90 n54
As others have said turn down your device volume a little.
LOST BUT NOT FORGOTTEN 2009 E90 335i AW... Black grills/jb4/lux angel eyes/clear side reflectors/and a few more small mods
2011 e92 335iSSSS Black |
08-01-2013, 12:39 PM | #7 |
22
Rep 457
My car does this also. I have a Galaxy S3 with a Monster 3.5mm 4ft cable. It's so annoying. I do use my USB drive mostly, but I have Google Music subscription, and want to listen to that once it a while. Highly annoying.
//|Phil
Current: 2011 Audi S4 Gone: 2009 e90 335 |6MT |
08-01-2013, 01:05 PM | #8 |
Rep 11
08-01-2013, 02:09 PM | #9 | |
Rep 75
Ive tryed other devices. Like I pad galx tab 2 and I pod all do the same thing. :/ |
08-01-2013, 03:17 PM | #10 |
Rep 11
Same problem, got one of these:
http://www.amazon.com/Kensington-Red...nsington+noise Problem solved. |
08-01-2013, 05:55 PM | #11 | |
Rep 75
08-01-2013, 05:59 PM | #12 |
40
Rep 191
Turning the volume on your device down will in fact increase the feedback. What you need to do is purchase a better aux cord not one from bestbuy. I did that and the problem was solved.
08-01-2013, 09:36 PM | #13 | |
69
Rep 1,766
08-01-2013, 09:45 PM | #14 |
Rep 75
its not the cable. ive tried multiple diff kinds and mine is a high quality monster cable with gold connectors.
08-01-2013, 09:47 PM | #15 |
Rep 75
just imagine how annoying this is... your driving down the road enjoying the nice weather and beautiful beach coast and you just hear this high pitch screeching sound while your favorite beats and playing. i cant wait till i get this shit fixxed!!!!
08-02-2013, 06:18 AM | #16 | |
53
Rep 450
08-02-2013, 10:24 AM | #17 |
12
Rep 253
Drives: 2009 E90 335i
Same here. I've tried all volume levels on my iPhone and nothing works. I have 3 cables. One was $20 and it still does the same thing.
I've given up on it. Impedence like mentioned before.
OFT Stage 1
08-02-2013, 10:33 AM | #18 |
1646
Rep 4,877
If you turn down the volume on the deck, it should go away. Mine had that issue, and with the aux input volume on the radio turned down, it is no longer there.
08-02-2013, 12:03 PM | #19 | |
42
Rep 91
Drives: 2007 328I Coupe
Get this and all your problems will be solved. And, it sounds better than the cable for some reason. http://store.123greetings.com/miccus...FUPl7AodgXcASg |
08-02-2013, 07:34 PM | #20 | |
236
Rep 1,037
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
08-03-2013, 01:23 PM | #21 | |
22
Rep 457
//|Phil
08-03-2013, 01:53 PM | #22 |
Rep 75
Ok guys apparently its NOT the car... its the Samsung galaxy Phones..... I called Samsung up and they told me they have numerous calls about people using there phone in cars and its interference with the Jack on the phone and the really big big battery they use..... Sounds like bulll shit to me... i paid full price for this phone... $650 dollhairs
I woke up at 6 am to bring the car to the dealer to watch 5 diff advisers try there phones and none had a problem except the one with the Samsung galx s4... same phone as mine |
