2010 2011 BMW 5 Series Forum F10 Changing rear reflectors |
07-31-2013, 05:28 PM | #1 |
BxBadBoyy88
61
Rep 360
Can't seam to find the link for the DIY for this. I just got my painted rear reflectors and wanted to know if the entire rear bumper needed to come off in order to replace??
2013 AW 535Xi
07-31-2013, 06:03 PM | #2 |
BxBadBoyy88
61
Rep 360
Never mind. I got it. Fellas , if the 3m tape don't work for you, wrap some thick string around the side with the metal clip and pull gently it will pop out.
2013 AW 535Xi
07-31-2013, 06:11 PM | #3 |
Sunburned
238
Rep 1,097
Drives: '16 F83 M4 Convertible 6MT
i just used a small flat head screw driver carefully and it pops right out.
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired 2011 Z4 SDrive35i 6MT- Retired |
08-05-2013, 07:47 AM | #6 | |
BxBadBoyy88
61
Rep 360
2013 AW 535Xi
08-28-2013, 02:21 PM | #8 |
Veteran
Rep 153
Here is a nice slideshow which shows how to change the rear reflectors. The slides dont show it but there is a small metal clip located where they are prying which holds the reflector in place. Its comes out fairly easy.
http://www.autoevolution.com/bmw-blo...2747.html#sjmp
2008 E90 M3 - Jerez Black
2012 F10 550i xDrive - Carbon Black 2015 Audi Q7 - Will be back to BMW at lease end |
08-29-2013, 11:57 PM | #9 |
41
Rep 776
the easiest way to remove it is to use a double sided tape and an L or T shape bracket. The bracket has to be slender to fit in fit between the indentation on the bumper. Stick the double sided tape on the bracket and stick to the reflector, pull it off and done. make sure pull straight as you may scratch the bumper if the reflector hits the surrounding indentation.
sorry no pics i'm too lazy to look for the bracket. |
