E90 335I ZF transmission Fluid
07-31-2013, 02:23 PM | #1 |
16
Rep 296
Drives: e92 328xi
Hi, I was wondering if this transmission fluid will work? Valvoline multi import? Anybody have any experience? I know mercon sp will work, but I don't have any oreillys by me. Closest one is 100 miles away.
http://www.valvoline.com/products/co...sion-fluid/137 |
07-31-2013, 03:57 PM | #2 |
16
Rep 296
Drives: e92 328xi
07-31-2013, 03:57 PM | #3 |
16
Rep 296
Drives: e92 328xi
haha just answered my own question
07-31-2013, 04:11 PM | #4 | |
103
Rep 2,783
BMW LT 71141, ETL-7045E and M-1375.4 applications Currently I am using Castrol Multi-import without any problems.
07-31-2013, 04:13 PM | #5 |
16
Rep 296
Drives: e92 328xi
check out the other link, It specifically list our transmission and recommends the Multi import, and its synthetic. Im going to try it too.
07-31-2013, 04:17 PM | #6 |
103
Rep 2,783
Just did, thanks!
07-31-2013, 05:51 PM | #7 |
1903
Rep 6,968
AMSOIL
AMSOIL now makes fluid that is compatible for BMWs. I have changed out my filter/pan and refilled it with Ams. Car works perfect.
08-01-2013, 07:38 AM | #8 | |
535
Rep 1,873
A less expensive but still good option is jugs of Valvoline Maxlife ATF from Walmart. It also lists LT71141 specifically on the label and is easy to get. If you DIY and change it often, this might be a better value than Amsoil which is expensive (but pretty much the best). Doing a pan drop, filter change and switch from genuine dealer LT71141 to Amsoil ATF solved all kinds of weird transmission behaviour in my dad's E39 540 that it had since new. |
