08 E90 side jack points ?
07-30-2013, 08:20 PM | #1 |
Rep 4
Just got me a 08 328I Sedan. I was checking out the side jack points and found the rectangular areas, but wanted to know if there should be any rubber bumper type part up in there . There is not and needing to know if that will cause me issues when I try to jack it up. Im a BMW noobie so was wanting thoughts from experienced owners... please
thanks, Mike |
07-30-2013, 10:00 PM | #2 |
Rep 295
There should be a plastic rectangular pad at the four jack points.
http://www.ecstuning.com/BMW-E90-328...Pad/ES1599379/ Since you said you found the rectangular areas I assume you already have what is supposed to be there. |
07-31-2013, 03:32 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-31-2013, 06:12 AM | #4 | |
General
17314
Rep 18,737
http://www.e90post.com/forums/showth...ghlight=trolly |
07-31-2013, 10:25 AM | #5 |
Rep 4
So I have to have the plastic rectangular pads in place? None of mine have this pad. Can the car still be jacked up without them in place? like if I get one of the jack pad adapters for my floor jack. just dont want to do any damage to it.. appreciate all the replys
MMIke |
07-31-2013, 12:52 PM | #6 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
hockey pucks work well between jack and points. Good for jack stands too. Just make sure you center them carefully.
07-31-2013, 02:49 PM | #7 |
Rep 4
So using a hockey puck cut to fit will allow me to use my floor jack to lift from the side points WITHOUT any of the plastic retangular jack pads installed? thanks
07-31-2013, 04:04 PM | #8 |
General
17314
Rep 18,737
You should really lift the car from the center jackpoint and place it down on jackstands underneath the lifting points on the side. This is the safest way to lift the car off the ground. My advice is to always lift the car completely off the ground (all 4 wheels) and place the car on 4 jackstands. It then cannot accidentally roll off the stands when you are underneath it.
08-10-2013, 12:11 AM | #9 |
Rep 31
Recently I'm going to change brake fluid with power bleeding tool by myself. I know that we have central jack points, but I am wondering if I can do my job by following these steps:
1. Lift my car from right rear side jack point by floor jack. 2. Take the right rear wheel off. 3. Lower the floor jack and keep right rear side jack point on floor jack. 4. Start bleeding. 5. Repeat. |
08-10-2013, 02:48 PM | #10 | |
General
17314
Rep 18,737
08-11-2013, 10:39 PM | #11 | |
Rep 31
08-12-2013, 02:58 PM | #12 |
General
17314
Rep 18,737
08-13-2013, 12:02 AM | #13 |
Rep 31
08-13-2013, 06:33 AM | #14 | |
General
17314
Rep 18,737
You can personally like to douse yourself in gasoline and lite yourself on fire, but you only get to do it once... Last edited by Efthreeoh; 08-13-2013 at 06:42 AM.. |
08-14-2013, 07:28 AM | #15 | |
Rep 31
