F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
ARMA SPEED
      07-26-2013, 07:12 PM   #1
johnnieb
32
Drives: BMW F30 318D
Post Front Park Distance Control (PDC) Retrofit DYI
Hi all, I'm going to use this thread to document and share my experience on retrofitting Front Park Distance Control (PDC) and all necessary disassemblies on my F30.
I'm attaching EBA 2338017 which is the official installation instructions for this retrofit which applies to F30 F31 F20 and F21 .
This is the necessary parts list for a Sapphire Black F30 with a non M front Bumper:
Description Part number #
Install.kit, Park Distance Control,front 66202338070 1x
Repair kit for bracket, bumper, front 51117324343 1x
Ultrasonic sensor, black 66209261582 4x
Cable Set Front bumper 61129260019 1x
Unit, center console 61319252912 1x
Center console control unit retrofit cable (included in 66202338070)
Decoupling ring PDC torque converter 66206923000 4x (included in 66202338070)
Center console unit
Included:
- Front PDC retrofit wiring harness
- 4x PDC Rings
- 10x cable ties (instructions specify 20x)
- Centre console control unit retrofit cable
Included:
- 4x PDC sensor holders
- 2x headlight washer holders
- 2x camera + PDC holders for Parking Assist
Edit 2013-07-28:
- added photos of the parts
- mention "Centre console control unit retrofit cable" and the sensor rings are included in the installation kit
Edit 2013-09-29:
- added photos of the installation and the Centre console unit
Edit 2015-05-10:
- added Centre console wiring info
Installation
Disconnect car battery!!!
I started with the Center console change.
For that we start by getting access to the console pulling the leather from the shift handle:
Then the button unit is fixed by two plastic springs on opposite ends:
The easiest way is to press on the top one by hand:
then on the 2nd one with a tool on the pointed area (you have to try and feel it):
The instructions state that a cable should connect pin 2 on the console to the ICM and on my car that was already connected.
What the instructions are missing is pin 1 and in the end the connections should be:
Centre Console <-> ICM
PIN1 GN/GE(Green/Yellow) wire <-> PIN28
PIN2 GE/BL(Yellow/Blue) <---------> PIN6 should already be connected
PIN3 <-------------------------------> PIN13 should already be connected
Notice: as you can notice from the pics of the kit, it comes with an extra 10 pin blue plug and with 2 cables, connected on pin 2 AND pin 1.
Assemble back the new console.
Front Bumper
Disassembly of the front bumper is pretty straightforward, just too many bolts
You'll have to get half of the bolts out of the front wheel inside trim to access some bolts for the bumper and disconnecting the fog lights and headlight washers if you have them.
On the guides for the PDC holders, drill the holes carefully to 18mm. Most probably you'll have to debur a little because with a perfect 18mm hole the sensors won't fit.
I tested each sensor on the hole without the holder to see when they fit perfectly
Go slow, go perfect
The PDC Holders have markings for their position: VLA, VLI, VRI and VRA
That is the order from left to right, when you're working inside the bumper
L for Left
R for Right
A for Outside
I for Inside
Firewall
Firewall access is actually pretty easy.
Start by getting the cover out of the battery connector. Has a red cover, can't miss it.
What I actually missed was a hole used for this cover, and actually used it to guide the cable through but only found that out in the end. Either way, I didn't found a better way to route the cable. Do your own analysis.
When you get the cover out you'll see 2 covers that get you access to the firewall:
On the other end, contrary to the instructions, I didn't need to disassemble the whole Glove compartment, just the bottom right dashboard trim.
When you puncture the firewall you'll get something inside over here:
My cable after routing it:
Now that the cable is inside the car, route it to the back of the car.
REM
Unplug the REM plug, get the 2 connector modules by unclipping them but be very careful, too much and it will break the sides:
Plug the connector modules inside the plug and reconnect it to the REM again
With all plugged in, reconnect the battery.
Coding
Coding is "easy" and since it's a change in VO you won't need a token for E-SYS
My car already had Rear PDC (option 507) and I want complete PDC (option 508) so we have to change that. Look for "E-Sys - How to change FA in F-series car.pdf" on how to do that.
Afterwards the modules need to be coded.
The simplest way is "ESYS -> Expert -> Code"
Select all ECUs and on "KIS/SVT Target" press "Detect CAF for SWE"
E-SYS will calculate the changes needed for the new VO options
Afterwards press "Code" and wait around 2 minutes
Check that you have PDC working!
Hope this DIY helps someone!
Last edited by johnnieb; 07-28-2018 at 06:34 PM.. Reason: Restore images (were on a remote server)
Appreciate 6
      07-26-2013, 08:25 PM   #2
BMW_F30
57
Drives: F30 2013
Awesome. Once you're done with PDC, retrofit the backup camera. Its super useful. http://www.bimmer-tech.net/ sells the OEM kit and they handle all required programming.
      07-28-2013, 04:48 PM   #3
johnnieb
32
Update
Update to the original post:
      07-29-2013, 05:24 AM   #4
johnnieb
32
Although I'd like to have the backup camera, the virtual lines are nice, but the investment is too high for what you get when you already have rear PDC.
I could do the coding myself but I think CIC is needed and I only have CCC
      07-30-2013, 07:21 PM   #5
Axman85
77
Drives: 335i x-Drive M-Sport Min. Grey
Centre console control unit retrofit cable (included in 66202338070)
Included:
- 4x PDC Rings
Included:
- 2x camera holders (I believe)
My car is going to BMW this week so I'll probably only start working on it next week
Edit 2013-07-28:
Where did you buy the kit?
      07-31-2013, 04:04 AM   #6
johnnieb
32
In the UK
      07-31-2013, 07:30 AM   #7
Axman85
77
From a dealer or on the web? If the latter please share the site. Hoping to get a retrofit for the rear.
      07-31-2013, 09:07 PM   #8
BMW_F30
57
Drives: F30 2013
If you have an F30 you don't have CCC. Does your car have Nav? If so, Backup cam is an easy retrofit. And if you don't have Nav www.bimmer-tech.net has an aftermarket solution that provides parking lines.
      08-27-2013, 10:54 AM   #9
K320
Puerto Rico
131
Drives: G01-X3 30i MSport
Where can i buy the rear pdc retrofit?
What to have that in my car and backup camera
      09-29-2013, 04:33 PM   #10
johnnieb
32
Installation guide and photos added!
Edit 2013-09-29:
      09-29-2013, 04:41 PM   #11
anotherguitarplayer
34
Drives: 2021 M550
2021 BMW M550  [0.00]
The part number for the rear retrofit kit is:
Non M - 66202296991
M - 66202339614
      10-08-2013, 10:24 PM   #12
K320
Puerto Rico
131
Non M - 66202296991
M - 66202339614
Thank's
      10-16-2013, 10:48 AM   #13
silverbeem
Drives: F30 316
Where to get front pdc parts?
      10-16-2013, 10:53 AM   #14
johnnieb
32
You can get the parts and the installation locally in Singapore from:
EleBest Pte Ltd
+65-97335000
Ask for Max. He was most helpful when I had an issue with my installation
      10-30-2013, 03:58 PM   #15
npgatech
npgatech's Avatar
Drives: 2012 BMW 335i
What if I don't have a rear PDC sensor? Is it possible to retro-fit an F30 without any parking assistance features? From coding perspective, I am fairly comfortable but not sure if hardware is available/compatible.
      10-30-2013, 04:11 PM   #16
johnnieb
32
There is a retrofit kit for Rear PDC and I bet a lot easier than Front PDC installation as the cabling goes to the REM which is in the trunk compartment.
Mind you, you'll need more parts then just the retrofit kit, sensors, etc
      11-12-2013, 12:30 PM   #17
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
What was the cost of this kit from a UK dealer?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      01-15-2014, 10:27 AM   #18
raj10800
Drives: G20 330i
Center console unit
Included:
- 4x PDC Rings
Included:
Edit 2013-07-28:
Edit 2013-09-29:
Installation
The instructions state that a cable should connect pin 2 on the console to the ICM.
On my car that was already connected.
No mention on the instructions about pin 1
Front Bumper
Go slow, go perfect
L for Left
R for Right
A for Outside
I for Inside
Firewall
REM
Coding
Issues
My sensors are working fine, only the PDC button on the center console isn't working. I'm still trying to figure out what the problem so if anyone got hints I'd really appreciate the help
Hi - how much did the kit cost you in UK?
      02-20-2014, 09:53 AM   #19
gumes
Drives: F30 316d 2013
Hi, did you resolve problem with PDC Button? I have this problem too.
      02-21-2014, 05:40 PM   #20
euro-r
euro-r's Avatar
34
Drives: 17' BMW X5 | MSport | MPPK
Cool
I only have rear sensor as well.
      03-08-2014, 03:18 PM   #21
Tommy_hf
Netherlands
70
Drives: F36 CQ M, Z4 E85 3.0iS MSL SC
I got a quote from the dealer, but it was about 970 euro's for parts alone! + 3 hrs of labour.
      06-18-2014, 08:58 AM   #22
Axi$
Drives: F30, S15
Thank you very much for sharing the info, I used your posts to make my front PDC work.
Concerning non-working PDC button, I connected pin #1 on central console module to pin #28, hope this information hope to solve your problem
f30post
