Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Touring Boot Trim Removal
      07-24-2013, 06:13 AM   #1
moltione
Drives: E91 320D Touring
Question Touring Boot Trim Removal
Hello All,
I have a e91 touring and need to know how to remove the boot Trim to get access to the top of the shocks.
Any help would be great!
Thank you.
      07-24-2013, 01:18 PM   #2
RemovedUser
Guest
n/a
Drives:
There are just those gray/black plastic plugs you can use a screwdriver or a plug tool to pop the center part up, this releases the clip then the clip can be removed.
One you remove all of them just pull the carpet out and you will have access to the top of the towers.
      07-24-2013, 05:25 PM   #3
moltione
Thanks for the reply but there doesn't seem to be any obvious plugs.
Will take a photo
      07-25-2013, 07:45 AM   #4
moltione
Seemed to have figured it!!
The right hand side of the boot can be accessed by removing the center boot board.
Then unscrew the black plugs that hold the right netting section in place.
Pull the trim away.
You should now be able to feel the top cover for the shocks behind the other trim
      08-05-2013, 07:22 AM   #5
gewse2k
Netherlands
19
Drives: 2014 F30 320i
See showpost.php?p=14253630&postcount=17
Tags
boot, e91, touring
