BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > 335i Oil leak near Coil packs w/pics
      07-23-2013, 04:32 PM   #1
law2004
38
Drives: 2015 435i
close please, fixed
      07-26-2013, 03:37 AM   #2
law2004
38
Drives: 2015 435i
anyone???
      07-26-2013, 03:55 AM   #3
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
Probably valve cover gasket.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      07-26-2013, 04:52 AM   #4
hugus311
Titanium silver + Sport + Premium
hugus311's Avatar
32
Drives: 2006 330i (E90)
+1
      07-26-2013, 12:53 PM   #5
catcher22
294
Drives: 2008 335xi Coupe
Yeah, it's probably your Valve Cover Gasket leaking.
I have pics almost identical to yours.
Pull out a coil or two and check if there's oil in the coils or plugs.
If so, I'd change those out after replacing the VCG as well. You could do it all in one DIY.
      07-26-2013, 05:52 PM   #6
law2004
38
Drives: 2015 435i
Thank you, yeah i just determined it was the Valve Cover gasket.. and also it looks like the Valve Cover itself is cracked.. look at second picture, do you think i need to replace that as well? its almost 300$ for the part itself.. or would i be able to JB Weld it?
Thanks
Sam
      07-26-2013, 06:19 PM   #7
GoRomeo
GoRomeo's Avatar
964
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
can you see the crack or you are just assuming? Could be broken bolts. I also have a leak but not sure which one is my issue...keep us posted
      07-26-2013, 07:21 PM   #8
law2004
38
Drives: 2015 435i
If you look at the Second picture, and zoom in the middle.. you can see a hair line crack on the gasket cover.
      06-12-2016, 10:03 AM   #9
Grand_hustle17
192
Drives: E90 335i
Wish i can see these pics
      06-12-2016, 11:10 PM   #10
scales82
Drives: 2005 E90 320i, RHD
me too, please put the pics back up. Just because you have fixed. it can help others!
      06-16-2016, 07:06 AM   #11
Donutz
140
Drives: 335i
These might help, but aren't the original pics from this thread. The first two are from my car, the last two are from my bro's car. Both of us had cracked valve covers.
