BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Just bought a 100K miles E92 335i, what services do I need ?
      07-23-2013, 02:11 PM   #1
anorphirith
No_Country
23
Drives: 07' 335i 6mt Cpe
Hello !
I just bought my first BMW E92 335i
it has 107K miles on the counter,
my question: what do I need to do to get it ready to drive it another 100,000 miles ?
I'm thinking:
-changing the transmission fluid
-replace the bushings ?
-replace struts ?
service records
http://s1314.photobucket.com/user/Jo...iamor/library/
      07-23-2013, 02:20 PM   #2
Potty_Pants
Potty_Pants's Avatar
66
Drives: 2012 Genesis Sedan Rspec
1st. get service records.
2nd post service records and ask for advice.
3rd have $2000 avail.
ppp
      07-23-2013, 02:26 PM   #3
Mr.Smithers
Mr.Smithers's Avatar
22
Drives: 03 Z4, 07 328, 11 535
Just save money for repairs
gxe2se37.50
      07-23-2013, 02:26 PM   #4
thenewrick
26
Drives: 2007 E93 335i Black Sapphire
Skip the bushings. Skip the struts.
Transmission, power steering, coolant, engine oil, brake, differential fluid changes.
Clean your intake valves and intercooler.
Replace air conditioning filter.
Alignment.
Spark plugs.
Make sure tire pressure is good and wear is good.
Run a fuel system cleaner just for peace of mind.
Replace your engine air intake filter/replace with aftermarket.
Replace valve cover gasket, oil filter housing gasket, PCV vanos solenoid with upgraded Rob unit.
-As for mods I'd recommend starting with just a BMS JB4 tuner and set it to the auto-tune map 5. It's easy, safe, can reverse it and will make the car more responsive and much more powerful.
Beyond that you're getting into cosmetic mods and deeper water with power mods that I wouldn't recommend until you're very familiar with how the car drives and looks.
Appreciate 2
bwhipp0.00
      07-23-2013, 03:30 PM   #5
Titanium3er
Titanium3er's Avatar
19
Drives: '08 335i, '03 Kawa Z1000
Bad advice. Only follow this if you'd like to end up paying 2-3x as much as you would doing preventative maintenance; and possibly much more.
Some might say its a little late to change transmission fluid, but just think of the cost of the fluid change vs the entire tranny.
      07-23-2013, 03:32 PM   #6
melloww22
melloww22's Avatar
105
Drives: 2011 335i E90
at minimum a full tune up of engine and transmission
replace O2 sensors, catalic converter, muffler, shocks and struts, alignment, brakes, tires, battery, purge IC, Fuel lines, etc
2500 avg DIY
      07-23-2013, 03:32 PM   #7
melloww22
melloww22's Avatar
105
replace O2 sensors, catalic converter, muffler, shocks and struts, do alignment, brakes, tires, battery, purge IC, Fuel lines, etc
2500 avg DIY
      07-23-2013, 03:40 PM   #8
kdbryce
I have to return some video tapes
kdbryce's Avatar
362
Drives: e70 X5M
Brave.
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
      07-23-2013, 03:40 PM   #9
litxus
58
Drives: 09 E90 335i sedan
ppp
+1
Service records will show you what was done so you don't throw money away.
Do not go overboard as some people say replace a whole bunch of stuff as it is not really needed, unless you have loads of extra cash laying around.
      07-23-2013, 03:40 PM   #10
DanielGonz
19
Drives: AW E92 335i 6 speed
2500 avg DIY
fuel lines!?
Some of the posts on this thread are pretty hilarious. I'm coming up on 100k and you guys are making it seem like this guys car is plagued from a non-caring owner.
07 AW E92 335 6MT [18" OEM 193's For Sale, PM me]
OEM Aero Lip | OEM Gloss Black Kidney Grills | KW V2 | Vorsteiner CSL trunk | M-Tech Rear Bumper | LCI Rear Taillights | Angel ibright Angel Eyes | 3000K HID fogs | 6000k HID low beams | AFE DCI | Full LED conversion
      07-23-2013, 03:45 PM   #11
thenewrick
26
Yea, melloww22's advice is pretty awful, just ignore those suggestions.
      07-23-2013, 03:53 PM   #12
Otruba_843
Otruba_843's Avatar
93
Drives: 2009 E90
Originally Posted by kdbryce View Post
Brave.
All I can say is that the OP has balls
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior
      07-23-2013, 03:59 PM   #13
Spool
Spool's Avatar
Vietnam
558
Drives: A few
If it ain't broke, don't fix it...
MKIV 6spd 1000hp Club
      07-23-2013, 04:07 PM   #14
deadmn1337
39
Drives: 2016 EB 435i
Thats a gutsy buy! Do preventative maintenance with fluid changes and find out if thermostat and water pump have been changed, those are the two major things that will be going out soon if they havent been replaced yet. Also probably time for new plugs.
      07-23-2013, 04:10 PM   #15
Killerfish2012
177
Drives: E90 335I, E92 M3
replace your oil pan gasket, thermostat, and water pump, all in one go. Relace all your vacuum lines with high quality silicone, especially the one behind the oil filter housing. Good Luck.
'07 335I w/ Mods
'13 X1 Stock
'11 X3 K&N
      07-23-2013, 04:24 PM   #16
edirtaynine
81
Drives: e92
id rather buy a used GTI instead of a very-used 100k-mile BMW.
e90post killed plastidip
Just say no to painted stock wheels
jm3as hooks it up
      07-23-2013, 04:29 PM   #17
Titanium3er
19
I don't see the point in replacing water pump and thermostat before they go. Get yourself AAA and replace it when you need to.
      07-23-2013, 04:45 PM   #18
tennis_pr0
67
Drives: 2--7 BMW 335i coupe
I have a hard time understanding why people make it seem like buying a 335 with high mileage is such a bad idea. I'm sure he got a good price on it, and just like ANY other car, you will have maintenance that needs ot be done with buying a higher mileage car, just with a 335 the maintenance will be more expensive.
But he does some basic maintenance that needs to be done, he is just as safe as any other 335 driver out there right? Of course, like others have said, service records are a must.
      07-23-2013, 05:01 PM   #19
SkyWalker_J
Drives: E92 Jet Black
If nothing is mechanically wrong and your up to date on your services, I would make sure you have a good tow service, and keep a few grand aside just incase something happens.
      07-23-2013, 05:03 PM   #20
tennis_pr0
67
Yeah I men as long as everything is up to date (meaning the previous owner (s) took care of it) then I think the worst that will happen is you have to drop a couple grand if something or somethings do break.
      07-23-2013, 05:07 PM   #21
BRD1234
BRD1234's Avatar
18
Drives: E92 335i Coupe
welcome!
not too long ago I purchased a new 335i coupe with a manual transmission, everything is great and is working. I would recommend just doing whatever service is needed.
my dad once told me "if it doesn't need a fixing don't fix it"
I love mine so far and I'm sure you will too! where do you live by the way? that could tell a lot about the car.
Congrats.
335i Coupe 6MT Montego Blue
      07-23-2013, 05:32 PM   #22
CruzS4e92
CruzS4e92's Avatar
Drives: 2009 E92 328i coupe
jesus mellow, new cat and muffler?!
OP what year and how much did you pay? just curious. any pics? i'd like to see how it's holding up at 107k
'09 328i coupe 6MT Sport
SG/CR - BMW SSK/alcantara boot - 30% Llumar - Shadowline - BBS Style 197 - LUX H8 V3 LEDs - OEM Aero Lip
