EGR Cleaner and Additives
07-17-2013, 12:19 PM | #1 |
229
Rep 3,489
Drives: Montego Blue 335d
Check this out amigos found it in YOUTUBE:
Heres the response for the XFT
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
07-17-2013, 12:34 PM | #2 |
229
Rep 3,489
07-17-2013, 12:52 PM | #4 |
229
Rep 3,489
Socom I went into that site cant seem to find any info on it please gives a link on it ok!!
07-17-2013, 01:00 PM | #5 |
3606
Rep 10,367
07-17-2013, 01:02 PM | #6 |
229
Rep 3,489
07-19-2013, 09:03 AM | #7 |
229
Rep 3,489
anyone else used this product?
07-19-2013, 09:46 AM | #8 |
23
Rep 294
Drives: 335D
I dont usually post but for $4 its super fishy to me, and while I'm here I might as well introduce myself. I've been eyeing the forums for about the same time I got my 335d just dont post. I like to view. The EGR cleaner seems like a good product I'm tempted. As for the additive as soon as I saw the price I say no. If you want to talk about additives look for ones with a high lubricity. I personally use diesel kleen and will be switching to opt lube xpd. The point of the additives for me is not performance but longevity. To make our cars last an eternity the wear on the engine components has to be very, very low. The wear scar of I recall was best rated at 450 microns was it and down for the best results. Optilube brings it down to I think 317 then biodiesel at 221. The reason as many should know is ULSD in the USA sucks for any form of diesels. No lube means lots of damage in the long run we have a dry fuel. So additives are used personally I used diesel kleen because it was cheap but id figured spending more couldn't hurt until I start my biodiesel plants. Gotta save that $$$$ haha. I'm sure many have read around about the different additives but go for the good stuff and you won't regret it.
Edits; http://www.powerstroke.org/forum/99-...anadyne-3.html Last edited by Nushibo; 07-19-2013 at 10:06 AM.. Reason: Some facts for ya over at power stroke, should apply to us too |
07-19-2013, 10:06 AM | #9 |
229
Rep 3,489
gracias and welkome
07-19-2013, 10:19 AM | #10 |
23
Rep 294
Drives: 335D
Thanks ill be around in the forums.
07-19-2013, 10:33 AM | #11 |
213
Rep 2,210
what is the point of the XFT though? 99% of our problems are between the EGR and the valves, this XFT treatment wouldnt do jack in that area since there is no fuel in there. The valvoline stuff might work, especially if its as good as it looked in that video, but you would still need to full the manifold all apart and go through the exact same process as a walnut blasting, plus it would probably take 20 cans to complete the job.
When I had mine apart, high pressure water (hose turned up with thumb over hole) did the same thing at the cost of only pennies, though IMO that valvoline stuff ought to work better once the larger chunks are blasted out. I would be inclined to trust Valvoline since they are such a big MFG and their base of products isnt a whole selection of snake oils, but Im more inclined to build my own walnut blasting machine (can be done for ~$200-$300 based on some mini forum threads) if I already have to break the engine apart anyway. Oh and the other issue being that this EGR + Turbo cleaner isnt available in the US from what I can find. |
07-19-2013, 10:44 AM | #12 |
229
Rep 3,489
Hooper I put this up as information for eveyone to know and if ANYONE had used this products to give us feedback
07-19-2013, 01:54 PM | #13 |
Rep 115
You have to consider the entire combustion cycle from the fuel filler cap to the exhaust pipe. The carbon build up is coming from EGR. If a fuel additive can improve injection and combustion efficiency it will reduce (to at least some minimal extent), the amount of particulate coming back through EGR. Worn injectors and HPFPs' will reduce overall combustion efficiency over time. They can be helped by lubricity-enhancing fuel additives. Other factors may affect it as well - tuning, electronic engine controls and their associated sensors, environmental conditions. Even an air filter overdue for changing or impaired by some environmental affect can greatly impact combustion efficiency.
The point is they all make more soot flowing back through EGR. |
07-20-2013, 01:12 AM | #14 | |
158
Rep 866
EGR has been with us for a long time. Not so carbon buildup. It may have nothing to do with EGR. You may be mixing up the types of accumulation, such as carbon buildup on valves with intake manifold oiling. It is likely that direct injection itself is to blame and there are threads that explain how Toyota has redesigned a hybrid injection (both direct and indirect components, the indirect may "wash" the intake valves with fuel) that may fix this problem. PL |
07-20-2013, 09:56 AM | #15 | |
3606
Rep 10,367
What would be interesting is if European models were having this problem and whether BMW redesigned the head for US models (I bet the didn't) . |
07-20-2013, 04:06 PM | #16 |
213
Rep 2,210
The typical injection design with injector outside cylinder wouldn't fix our problem anyway unless you injected an auxiliary injection with cleaners at the EGR/throttle body.
07-22-2013, 09:19 AM | #17 | |
Rep 115
My memory for snarky comments with incoherent content serves well. Last edited by acewiza; 07-23-2013 at 01:47 PM.. |
07-23-2013, 07:03 PM | #18 | |
158
Rep 866
http://en.wikipedia.org/wiki/Exhaust...lation#History PL |
07-23-2013, 07:28 PM | #19 | |
213
Rep 2,210
I wonder if someone with a 335D has been on that wiki page updating the soot+oil intake fouling or which other diesels have the same issue we have since whoever updated the page definitely shares our carbon buildup pain |
07-24-2013, 12:19 AM | #20 |
158
Rep 866
I don't think the soot and oil buildup is the same as the carbon buildup we are seeing on the valves with direct injection, but could be wrong. Cleanup of one is different than the other, as the oily intake manifold is not the same as the head and valves.
If it is just a matter of burning fuel more efficiently, which the pollution control regulations don't help with, then the trend may have tipped toward now covering the valves rather than just the exhaust intake ports. The 335d also seems to have some narrow intake ports with the complex twin turbo design, so I don't really know. But the latest diesel engines seem capable of good efficiency and EGR has been around since at least WW2 (I have a catch can from that era ready to be used if possible from an old turbo prop design, new old stock), the differences may be something like direct injection or something else specific. Likely culprits are pollution controls, direct injection, new fuel additives, that sort of thing. Things that have changed since the old days when carbon buildup was less common or unheard of in gasoline engines. To start saying that everything that has anything to do with an engine has something to do with it is a bit too much and is a non-solution to this problem. My 2c PL |
07-24-2013, 09:03 AM | #21 |
Rep 115
Current U.S. EPA highway diesel nox standards took effect for model year 2007. There certainly were a few cars and manufacturers experimenting with EGR on diesels (due to previously existing euro standards) before then, but it was not an implied mandate, nor was it widely implemented on diesels made for the U.S. market including light duty pickups in the U.S. until 2007.
07-24-2013, 11:24 AM | #22 | |
158
Rep 866
http://www.myturbodiesel.com/1000q/e...ogging-TDI.htm PL |
