TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Overheating
      07-16-2013, 02:31 PM   #1
tb30570
tb30570's Avatar
53
Drives: 2008 BMW 335xi Coupe 6-Speed
Overheating
My car started overheating yesterday and went into limp mode. It was 91 degrees out, I was on the highway with the AC on.
I'm running an OTS Cobb tune for stock engine with 93 octane fuel. I run 93 and my engine is stock so I assume the tune should be fine.
Should I try going back to OEM tune before moving on to other trouble shooting options?
2008 BMW 335xi Coupe 6-speed, 12.8 @ 107
2000 Chevrolet Corvette Z51, 11.4 @ 123
2005 Saturn Ion Redline, 14.1 @ 100 (sold Jun-2013)
      07-16-2013, 02:35 PM   #2
N8N
N8N's Avatar
170
Drives: 2009 E92 335i 6MT
yes, but I don't think the Cobb is the problem... but if you end up taking it to the dealer you want any relevant codes to be readable by them and the tune out so you may as well uninstall the Cobb now.
I'm running Cobb Stg1+FMIC and it was 95F out yesterday, drove a couple hours both on highway and in stop and go traffic, my oil never got over 240-245 (I couldn't see water as I didn't have the Cobb plugged in) so I don't think the tune is your problem.
      07-16-2013, 03:18 PM   #3
tb30570
tb30570's Avatar
53
It stinks you can't see coolant temp without a Cobb plugged in. I don't think I've ever had a car that didn't show coolant temp.
      07-16-2013, 03:56 PM   #4
tb30570
tb30570's Avatar
53
I think my water pump is toast
p2e81
p2e82
      07-16-2013, 03:57 PM   #5
N8N
N8N's Avatar
170
I would guess yes, might as well replace thermostat at same time
      07-16-2013, 04:10 PM   #6
tb30570
tb30570's Avatar
53
looks like I'm not the first with this issue:
http://www.e90post.com/forums/showth...=621838&page=2
      07-16-2013, 04:13 PM   #7
tb30570
tb30570's Avatar
53
I'm over 40k, so I'm guessing the warranty on this is over.
I found a DIY for a automatic. Somebody posted a video in there for the manual too.
http://www.e90post.com/forums/showth...ump+thermostat
I have to install my new IC, so maybe I'll do both at the same time.
where is a cheap source for parts?
      07-16-2013, 04:26 PM   #8
thegrinchboy
thegrinchboy's Avatar
62
Drives: '11 335xi, '18 X1, '21 M2C
Originally Posted by tb30570 View Post
is there a DIY for water pump and thermostat? I'm over 40k, so I'm guessing the warranty on this is over.
The BMW new car warranty is 4 yr/50K from initial in service date. Depending on when your car was put on the road, you may or may not be covered.
http://www.bmwusa.com/Standard/Conte.../Warranty.aspx
      07-16-2013, 04:27 PM   #9
N8N
N8N's Avatar
170
I haven't done it, just did a quick search
http://www.e90post.com/forums/showthread.php?t=784416
I thought warranty was 50K miles? you're probably over on time though what was your in service date?
      07-16-2013, 05:13 PM   #10
tb30570
tb30570's Avatar
53
I called and found out the warranty expired on May 26th 2012.
      07-24-2013, 11:50 PM   #11
ek99civic
BMW Noob
ek99civic's Avatar
Drives: 2008 335i
Has anybody had overheating problems with a Cobb OTS tune?
Why would you automatically think that the problem was from the tune?
