Went drag racing and car broke again.
07-14-2013, 08:45 AM | #1 |
41
Rep 800
So after the last fix by my friendly BMW dealer by replacing the dpf my car has been trouble free two weeks and I decide to take it drag racing.
I went to an 1/8 mile. My best was an 8.86 but most of my runs were in the 9.0-9.2 range. I beat every car I raced all night. On the last run right in the middle of the race I get a engine malfunction and reduced power message and lose... I was soooo pissed off. No ses light but I got home and turbocharger under boost condition is pending in the computer. This is the same code they were fixing the car for before they replaced the dpf. I was so pissed off I even went car shopping, but all the cars I drive are pos Only cars I actually like are BMW Audi or Infiniti... But BMW is better. So I didn't trade and cars going back to dealer. I don't want to do a dpf delete just yet because it would totally void my warranty and don't really know what to do at this point... Any input fellas? |
07-14-2013, 08:49 AM | #2 |
353
Rep 1,005
Drives: GMC Sierra
how many runs before this happened?
We grow food to feed the animals so we can eat the animals
07-14-2013, 09:13 AM | #3 |
411
Rep 3,049
Drives: 2009 BMW 335d
Could be your turbo actuators. Do you find a long lag before the second turbo kicks in at 3K rpm?
07-14-2013, 09:32 AM | #4 |
41
Rep 800
07-14-2013, 10:11 AM | #5 |
411
Rep 3,049
I meant lag after you saw the fault message.
07-14-2013, 02:33 PM | #7 |
614
Rep 2,410
Were you monitoring EGT's and coolant temps? How about boost levels? Was the car trying to do a DPF regen during the pulls? What kind of mods are you running? How long between pulls and was the car cooled down between? What were ambient temps?
It's possible the engine/DPF were getting really, really hot if you weren't monitoring things. Also possible the air charge pipe sealing gaskets were not able to hold pressure due to excessive heat under the hood. If you get a tool (Bavarian Technic or Android Torque) that will show you those operating conditions you could gain a lot of insight into what's going on when you are really pushing your vehicle in this type of extreme utilization. |
07-15-2013, 07:05 AM | #9 |
229
Rep 3,489
Drives: Montego Blue 335d
wish you luck amigo on this
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
07-15-2013, 10:15 AM | #10 | |
41
Rep 800
The ambient temps started at 100F and dropped to about 93F as time went on. I was not monitoring any temps and neither was I monitoring boost levels. I dont know if it was trying to do a regen, but I'm suspecting it was. I have a reflash by ecotune. The code that I was able to read with my hand scanner was a turbo underboost condition. It is possible that the dpf got too hot during the regen at WOT and it cut the power to keep it from melting down. I really wish these bmw cars would indicate when a regeneration cycle is performed just like my ford diesel truck. I think I'll pick up one of these bavarian technic tools and start monitoring things. I will be dropping the car off at the dealer tomorrow and see what else they can find. |
07-15-2013, 12:38 PM | #11 | |
614
Rep 2,410
You might want to also consider the Android Torque app if you have that type of phone or a tablet with android OS. With a bluetooth OBD dongle it's super easy to use. Much easier than the Bavarian Technic (although it can do and see way more than Torque can). I'm able to see the EGT's and boost, and its obvious from the EGT and EGR/Throttle behavior when the car is doing a DPF regen. http://www.e90post.com/forums/showpo...4&postcount=23 |
07-15-2013, 12:48 PM | #12 |
133
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
If its under warranty, return your car back to stock and get it fixed. Not sure how they'll react if the cars modded out and you told them you tracked it. Would be worth making it stock and using it warranty.
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
07-15-2013, 01:05 PM | #13 |
41
Rep 800
They already replaced the dpf and other stuff on it while flashed so its not an issue.
07-15-2013, 01:07 PM | #14 | |
133
Rep 1,945
07-15-2013, 01:11 PM | #15 | |
41
Rep 800
07-16-2013, 08:02 AM | #17 | |
Rep 115
Looks Nice, but Maybe You Can't Have It...
Wonder when they will update it for later years and sell it in the U.S.? |
07-16-2013, 10:04 AM | #18 | |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
So, from looking at the Torque shots in the link, during Regen the EGT1 temp goes way up and the EGR falls to zero percent, and after Regen, the EGT1 temp falls back to "normal" and the EGR percent climbs up to above 90 percent. Correct? Now I need to decide whether having the Torque app running all the time and thus occupying the OBD port, or having the JBD CAN tool occupying the OBD port. I wonder if the Torque app can do everything I need to do, not for setup, but for ongoing daily use, that the CAN tool does for me, meaning seeing all the codes that might be thrown by the JBD, and clearing them as needed?
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
07-16-2013, 01:15 PM | #19 | |
614
Rep 2,410
It's incredibly useful. Especially for doing fuel filter changes as its the only way I was able to get the low pressure pump to turn on so I could flush the filter and remove air from the fuel system before starting the car (very important for HPFP longevity and health). |
07-16-2013, 01:19 PM | #20 | |
614
Rep 2,410
One thing to note, I'm unable to see the shadow codes with torque, but can with the BT. Really, you should get both :-) |
07-16-2013, 01:52 PM | #21 | |
Jumping Jack Flash
324
Rep 1,692
07-18-2013, 12:40 PM | #22 |
41
Rep 800
so a bit of an update. sa called yesterday. he said the mechanic will be replacing the electronic vacuum control unit since the turbos are actuated by vacuum, or the wastegates.. or something lol. I sure would love to see a diagram of all this piping in there. Hopefully will get car back tomorrow and see if I can hook up torque to it and see where we are.
