Bird poop
07-11-2013, 12:01 PM | #1 |
62
Rep 460
Bird poop
Does anyone know how safe Poorboy's Bird Sh#t Remover is on clear coat and paint? After removing the bird shit with this product, do you have to coat the area with something to protect the paint?
There's a lot of bird shit in SF. :-/ |
07-11-2013, 12:29 PM | #2 |
21
Rep 687
Why didn't you just use soap and water?
07-11-2013, 12:47 PM | #4 |
456
Rep 6,478
The key with bird crap is to get it off quickly, before it etches the paint. If it hasnt baked in, you can any sort of apc or quick detail product to get it off.
07-11-2013, 12:56 PM | #5 |
681
Rep 3,696
I just get a paper towel which is moist. Some warm water in a cup which I pour on top of that $#1+, then let it soak. Once that $#1+ is easy to manipulate... I gently remove it with the moist paper towel.
I do that over and over again until it's gone. I never had any issue with it etching and I don't leave that $#1+ on my car for more than a day (The second I notice it... I deal with it). If you are having problems after the initial clean up, you might want to try to clay bar that part or if that doesn't work... try to use some rubbing compound on it next? you should also consider waxing your car and leaving a good layer of wax always on the car. |
07-11-2013, 01:41 PM | #6 |
///M
227
Rep 2,248
This is a big problem for me because there's a tree on top of my driveway and I can't go for more than one day before I find like 4 bird poop spots on my car. I just got into my car before and there's one conveniently placed right above the driver side door handle. I did a bit of googling and I saw someone on this forum say to take an old bottle, clean it out and make a small hole on top of the cap and then fill it up with water and spray it onto the poop like a pressure washer. It worked pretty well but it took a couple of trips.
07-11-2013, 01:48 PM | #7 |
60
Rep 1,024
You need to try and "scoop" it off rather than "rub." There are often pebbles and little granular things in there that can scratch. It doesn't matter what you use, even if it's just water, what matters is that you do it ASAP.
07-11-2013, 02:26 PM | #9 |
38
Rep 823
Car care product for bird s*&# lmao, Cracks me up. Paper towel/water or wash car. If it leaves behind "mark" in paint Light buffing compound will take it out and then wax the area.
/// OEM /// |
07-11-2013, 03:13 PM | #10 |
62
Rep 460
Good point on trying to scoop it out rather than rubbing it out.
I guess soap and water is good enough if you catch it right away (that's what I have done in the past), but if it has already dried up than it gets harder to get it off and that's why poorboy's product might help dissolve the dried #### a little bit better. Thanks for the comment that poorboy's product is safe on a clear coat. I empathize with the person who has to park underneath a tree. I have a similar problem. |
07-11-2013, 07:37 PM | #11 |
31
Rep 547
Tell me about it.... I live in SF as well. The only thing good going for us is the weather. If we have "Real" summer like everyone else then we will be in some serious trouble with etching.
A friend of mine who lives in San Jose had the pleasure of having bird bomb permanently etched to his roof. This happened in less than an hour in the summer heat (100+ degrees weather) but then he never waxed his car. The lesson is......You should be fine just as long you keep up with your LSP (Wax/sealant/Coating) and remove it as soon as you can.
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
07-12-2013, 10:38 AM | #12 |
62
Rep 460
haha yeah the weather helps and I'm in the sunny part of the city. I go to California Detailing for my clay/wax about every 6 months and simple exterior wash with wax once in between. How often is your car waxed to protect against the bird sh#t?
07-12-2013, 06:16 PM | #13 | |
31
Rep 547
Lately, I been doing quite a bit more of coatings on cars and I am considering doing the same to my DD. I am planning to do Gtechnig C1 and top it with Gtechnig Exo. Durability of these products measure in years. The extra thickness and hardness the coatings provide should serve me well against bird bomb since I live next to Golden Gate Park.
07-18-2013, 06:25 AM | #16 |
Rep 79
A wax in a hot climate doesn't last, try a paint sealant instead. 2 coats of Blackfire paint sealant on a PROPERLY prepped surface will give you 6-8 months protection in your climate (must wait 8 hrs in between coats for best results). If you want better protection, consider a surface coating like GTechniq C1/EXOv2, Opti Coat 2.0 or CQuartz.
07-18-2013, 07:05 AM | #17 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
Why dont you guys cover paint in Coatings like CARPRO CQAURTZ or Optimum.... you dont need to worry about these things after?
My car is has 2 coats of CQUARTZ applied 6 months ago after that i dont waste my time washing, polishing etc,i just wash it and use CARPRO Reload after wash while drying the car. I keep a spray bottle of Optimum no rinse mixed with water in my car and when i see bird poop on the paint,i just spray ONR and scoop it with MF Towel. |
07-18-2013, 08:40 AM | #18 |
704
Rep 2,015
Drives: '05 M3 6MT
Quick Detailers do an amazing job on bird crap...couple sprays and the crap should very easily wipe off with a microfiber cloth.
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
07-18-2013, 10:20 AM | #19 |
93
Rep 1,509
look up Junkman3000 on youtube. He has a video on removing bird crap and it's the best technique I have seen.
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior |
07-20-2013, 10:31 PM | #21 | |
38
Rep 627
Here's how I do it. http://www.autogeekonline.net/forum/...-dropping.html Always carry a couple towels and a quick detailer and a bottle of water in your trunk. If the bird poop has dried and harden then it will be very difficult to take it off without damaging the paint. First I get a towel and pour a lot of water on the towel and let it soften up for 5-10 mins. Then I use the method in the link above to get it off. It might take a few tries a 2-3 towels if you have a lot on your car. |
