6AT transmission fluid change
07-10-2013, 09:01 PM | #1 |
30
Rep 452
Just picked up my car after having the transmission filter and fluid changed, the tranny felt good before and now it feels even smoother. 49K on the odometer.
GIAC, Alpina TCU Flash, Ohlins, Brembo, Eisenmann, Quaife, Evolution Racewerks, Wagner Tuning, AFE, M3 suspension bits
07-10-2013, 09:47 PM | #4 |
30
Rep 452
Harold at HP autowerks did it, I believe he used Redline ATF. Price was $379 for parts(new filter and 7 quarts) plus 2 hours of labor.
07-11-2013, 07:16 AM | #5 |
3573
Rep 10,352
About to get mine done over the next week. Will have 50k on the odometer.
Parts: $288 (I'm replacing the sealing sleeve as well). Labor: $225 Total: $513 + tax. I'm using Lifeguard6 ATF. Last edited by F32Fleet; 07-11-2013 at 07:26 AM.. |
07-11-2013, 08:19 AM | #7 |
3573
Rep 10,352
1. The programming on my diesel is such where during city driving or winter starts it'll hold 3rd or 4th gear @ 2k rpms. IMO it was done this way for emissions reasons because diesels shed heat quickly when idling. It's the one thing I dislike about my car.
2. I drive mountains 3. Although BMW has been known to offer goodwill replacement on out of warranty cars I didn't want to risk it vs spending $500. 4. Re-sale. I will probably get a newer car 2 yrs from now. 5. I consider 1&2 to fall under ZF definition of "severe service" which recommends an oil change @ 50-70k miles. Last edited by F32Fleet; 07-11-2013 at 08:13 PM.. |
07-18-2013, 08:39 PM | #8 |
62
Rep 460
My car has 38,000 miles. BMW dealer says not to change the AT fluid ever and that it can cause more damage. What's the truth?
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
07-18-2013, 08:50 PM | #9 |
62
Rep 944
07-18-2013, 08:51 PM | #10 |
62
Rep 460
So what's the best interval to change the AT fluid?
07-19-2013, 06:17 AM | #11 |
535
Rep 1,873
If it were my car (meaning the fluid change would be DIY) I would probably do it after break in and then every 30,000 miles/50,000km. If I were paying for the service, I suppose I might stretch that to break in and every 50,000miles/80,000km.
By doing it at all you're ahead of the game. Other than $$$, you can't change it "too often" for the mechanicals. Because I DIY everything, I'm usually pretty aggressive with fluid changes. That being said, even doing fluid changes "overly often" I can always perceive some kind of improvement to the system with fresh fluid. That means the old fluid was degraded to some extent even at my early interval. It's on your mind - change it now. Especially for the first change (I assume you're running factory fill) I would also change the filter. Unfortunately I believe that on newer BMWs this means you also need to replace the pan part so it's $100-$200 for the part instead of a $20 filter element. |
07-19-2013, 07:45 AM | #12 |
3573
Rep 10,352
ZF specifically has a "severe service" oil change interval somewhere between 80,000 km and 120,000 km or 8 years, depending on the load.
It's up to you to decide whether you qualify for severe service. Visit ZF website for approved lubricants. |
