How to top off transmission fluid?
07-10-2013, 01:18 PM | #1 |
28
Rep 235
I know the fill plug and drain plug is under the car. But is there a tank or something under the hood where I can top off the tranny fluid, or is the only going under the car and opening the fill hole?
Reason why I ask is cause is just a long process to go under the car and messy. Thanks in advance.
07-10-2013, 02:39 PM | #3 | |
3576
Rep 10,356
07-11-2013, 02:49 PM | #4 |
28
Rep 235
Ok thanks, just a maintenance I use to do on my old Japanese cars and figure to do it for my 335i. But after some reading, there's actually no need for this.
07-11-2013, 03:13 PM | #5 |
174
Rep 614
The only way to do this is from under the car. If you open the fill hole without the engine running, expect a quart or more of transmission fluid to come gushing out.
The only correct way to do this is to have the car running, the transmission fluid around 100degrees F and make sure the car is level. You can then open the fill hole and use a transfer pump to pump fluid into the transmission until it starts seeping back out of the fill hole. |
07-11-2013, 08:42 PM | #6 | |
General
17317
Rep 18,740
07-12-2013, 09:44 AM | #7 | |
28
Rep 235
07-12-2013, 09:59 AM | #8 | |
1781
Rep 4,456
I am part of a small site for another car forum and its great, everyone is very helpful and it runs great. Of course there are a few bad apples but that with any forum. |
07-12-2013, 10:26 AM | #9 | |
28
Rep 235
07-12-2013, 05:56 PM | #10 | |
General
17317
Rep 18,740
My comment to you was to make you think and apply logic to your problems. If you want to work on your car, then learn some basic mechanics understanding and a few laws of Physics such as Gravity (all mechanics are based on the principles of physics). The point being you can't fill a cavity from the lowest point of it using a gravity fed process. If you want to go through life depending on other people to answer your questions for you before you have thoroughly thought them through then you'll have a tough road ahead of you. Had you taken the time to read the owner's manual section on what is under the hood, you would have found that there is no "tank" that holds transmission fluid. Additionally, you never mentioned whether the car has a manual or automatic transmission, which might have helped other forum members better answer your question. |
07-12-2013, 06:07 PM | #11 | |
1781
Rep 4,456
It's not that big of a deal he asked the question in the first place But I am sure you will have to have the last word so I look forward to your next post ! |
07-12-2013, 09:07 PM | #12 |
28
Rep 235
Well we have fill caps for many other fluids under the hood wheres the components are under it, on my old Subaru there was a fill hole under the hole for the tranny fluid. But I guess.......
07-12-2013, 09:41 PM | #13 |
General
17317
Rep 18,740
Yeah, you will. His question was totally stupid. He knows nothing about cars; nothing. Call me a troll all you want. He shouldn't be allowed under the hood; and he is the typical demographic BMW is now aiming for: "Oh, my car is low on oil, I should take it to the dealer so they can get the light to go off; I hate lights...
07-12-2013, 09:47 PM | #14 | |
General
17317
Rep 18,740
1) Engine oil 2) Coolant 3) Washer fluid 4) Power steering fluid (maybe you should get an F30; they eliminated this one) and.... 5) "oooh, where's the brake fluid go?" (next to the blinker fluid I think!) OMG! |
07-13-2013, 12:27 AM | #15 |
Guest
Rep n/a
Drives:
lol agreed. If there's no ATF dipstick tube, where exactly would you hope to fill the trans up aside from the actual FILL HOLE!?!
You wanna talk about trolls, let's start with the existance of this thread to begin with. A simple search first would have yielded multiple DIY articles on this site with pics and directions; which is why this is a pointless thread to begin with. |
07-13-2013, 04:22 AM | #16 | |
28
Rep 235
Why do you have to be While I'm just
07-13-2013, 04:22 AM | #17 | |
28
Rep 235
07-13-2013, 04:57 AM | #18 |
General
17317
Rep 18,740
Brandondroy, seriously, I'm not trying to be a dick here, so don't take it that way; but if you are serious about performing the maintenance and service on your car you need to better educate yourself. It's great that you are taking interest in the health of your 335i, but from your question it is apparent that your knowledge of cars is not at a level that it needs to be to actually perform the maintenance tasks required.
I sincerely suggest that you buy the Bentley service manual for the E9X. It has excellent sections on explaining how the various systems of the car operate, and is written at a technical level that a novice can understand. It is the best resource that you can get to better understand your particular car and cars in general. Good luck to you. |
07-13-2013, 05:02 AM | #19 | |
28
Rep 235
07-13-2013, 09:15 AM | #20 | |
103
Rep 2,783
As for everyone else,
07-13-2013, 09:29 AM | #21 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
Can't believe I'm writing this but I feel comfortable recommending the advice of Efthreeoh. He(she)'s put major miles on his car, knows DIY and has written some great stuff on this forum, under this name and another. Very helpful person.
