A Stuck Door....
12-03-2005, 03:49 AM | #1 |
18
Rep 740
Drives: e90 325i
A Stuck Door....
Did anyone have a problem when the doors are unable to close tight
Mine seem to have stuck from time to time becuz of cold weather? Sometimes after I open the door, get inside and try to close it, the external handle does not seem to return to the original position and hence i cannot close the door properly. i have to pull the handle a couple of times to 'reset' it, then it will close properly.... this is hard to describe, in a nutshell, i can't securely close the door
e90 325i Jet Black / Sports Pkg / Auto
12-03-2005, 04:40 AM | #2 |
101
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
might need to get service to lubricate the handle's internal workings to open/close easier for the cold weather.
cheers.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
12-03-2005, 10:14 AM | #3 |
Bemuri
Rep 124
Coreslogic I have noticed the same here in Finland that door handles get stuck when it is cold.It pissis me off.I tried to lubricate them with some anti freeze lubricant.It helped as long as I did not wash the car.I think I am going to call BMW about this matter here in Finland.
Alpine Weiss 320i,(man)sport package,17"Breyton Inspiration wheels,through load system,proff radio,hifi speakers,bi-xenons,auto air-condition,alarm,light package,pdc,rainsensor,cruise control,cup holders,heated seats,headlamp washers,tinted windows rear,Ac-Schnitzer aluminium pedals.
12-03-2005, 10:54 AM | #4 |
37
Rep 314
Drives: E90 //M Sport 320i S/Black
In extreme cold every wire I think expands a small bit, and in extreme heat shrinks a bit. That I am sure is what is causing your problem. Im sure in early spring or summer things will return to normal. Just think of the things in your freezer @ home. Same principal I suppose.
Just taking a chance here. Dont bash me if I am wrong. |
12-03-2005, 11:25 AM | #5 |
14
Rep 502
I had the same exact problem, but only on driver's side doors. I lubricated the "unlatch mechanism" with some sil-glyde on a q-tip. Handles return to position flawlessly. I will post a pic of exactly what I mean later today. It will take you 15 seconds per door...
see ya
06 325i. IT'S HERE!- 08 E92 328xi, Premium, Auto, Cold- Montego Blue |
12-03-2005, 11:42 AM | #6 |
14
Rep 502
I'll be gone for the day, so I'll post now.
Instructions: Get a flashlight and locate the door latch on the door. Shine flashlight into area where arrow is pointing and look down in there. Pull door handle from outside and observe a piece of curved metal sliding on a plastic slide. Lubricate lightly. Pull on door handle from outside a few times and it will now return after pulling it to get in. Good luck.
see ya
