Part number for 07 E93 rotor screws and DIY for the e-brake?
07-02-2013, 08:23 PM | #1 |
26
Rep 606
Stripped the screws that hold the rotor to the car and need to replace them tomorrow. I was hoping someone knew the part number for them.
I also bought some e-brake maintenance items but only found one DIY: Anyone know of another DIY, or tips on how to do the job? |
07-02-2013, 10:34 PM | #4 |
26
Rep 606
I'm trying to adjust it and figured it couldn't hurt to throw some new shoes and bits in there while I'm replacing the rotors. If it's too complicated to try and mess with the E-brake assembly in the wheel then I might not bother.
07-03-2013, 06:01 AM | #5 |
General
17364
Rep 18,760
All the e-brake is is a small drum brake without the hydraulics, it adjusts the same way a drum brake does. Set the brake pull-handle to 7 clicks and even up the cables (if they need it) then set the brakes at the wheel for a some drag at the brake, then tighten up the adjusting cables so the brakes will hold the car. Oh, and ALWAYS get new rotor screws when you do a brake job on any BMW. The only way I've found to not damage the head is to use a butterfly impact wrench.
