Is this engine coolant?
07-02-2013, 09:30 AM | #1 |
Rep 33
This morning I discovered a small puddle of a blueish green fluid right under my passenger side skirt. Is it engine coolant leaking? Its dripping right under the passenger side skirt adjacent to the jack lift point. I checked the engine coolant level and its fine and the car has not given me any warning light or low coolant fluid yet. I plan on removing the skid pates this weekend if its coolant i hope i can pin point the location its leaking from.
Specs: Bone Stock 2008 e92 N51 engine 77,000 miles. |
07-02-2013, 09:53 AM | #4 | |
Rep 33
07-02-2013, 10:01 AM | #5 |
535
Rep 1,873
As said, that location and colour could be either washer fluid or coolant. Use smell, evaporation, and checking what fluid you are now low on to narrow it down.
07-02-2013, 11:01 AM | #6 |
103
Rep 2,783
Agree, smell it. Also, coolant is slimy/slippery.
07-02-2013, 11:10 AM | #8 |
136
Rep 1,598
If you experience low washer fluid warning alot then that's the washer fluid leaking, I have the same problem. You'll have to replace the little motor, easy to replace but a tedious job to get to.
07-02-2013, 11:45 AM | #10 |
964
Rep 3,854
Drives: 330i, 135i
Thats most likely windshield fluid. smell it and you will find out. Coolant has a distinctive odor.
If you smell windshield fluid is smells like Windex kind of. |
07-02-2013, 01:26 PM | #11 |
General
17315
Rep 18,737
Based on the location of the puddle it is washer fluid. The washer fluid tank is located in the rear of the right-side front fender There is no coolant lines near that part of the car. Heater hoses are near there, but farther inboard. The coolant reservior is in the font of the wheel as is the rest of the cooling system.
07-02-2013, 08:29 PM | #12 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
+1, most likely washer fluid in that location.
