06-28-2013, 10:18 AM | #1 |
207
Rep 603
Brakes buying decision helper: "Factory", "M Sport Brakes", "M Performance Brakes"
BMW just confuses us customers/drivers with all those possible brake options.
I hope this will bring some light into brake dust of F3x brakes! The following link takes you to a Onedrive Excel list where I list all the F3x Modells and all the brake variants (standard and options) until the 335i Engine model. I did not do an update for the engine change models like 340i. Just too much work. However look up the origial brake size of your model in sites like realoem (link far below) https://1drv.ms/x/s!AqdJMMUQxA-nhZs6_JWYyQG6amQ0jA Original Brakes Variant 1: Front rotor: 300x22mm (Millimeter) / Brake Caliper with 1 piston Rear rotor: 300x20mm / Brake Caliper with 1 piston Original Brakes Variant 2: Front rotor: 312x24mm (Millimeter) / Brake Caliper with 1 piston Rear rotor: 300x20mm / Brake Caliper with 1 piston Original Brakes Variant 3: Cars with Sport Package P337A = YES Front rotor: 330x24mm (Millimeter) / Brake Caliper with 1 piston Rear rotor: 300x20mm / Brake Caliper with 1 piston (some cars show also to have 330x20mm Rear rotor with this upgrade) Original Brakes Variant 4: 335i, 335d or Cars with Reinforced Brakes S102A = YES Front rotor: 340x24mm (Millimeter) / Brake Caliper with 4 piston Rear rotor: 330x20mm / Brake Caliper with 1 piston Option (Factory upgrade) with S2NHA M Sport Brakes (blue colored): S2NHA Variant 1: all not listed under Variant 2 Front rotor: 340x30mm (Millimeter) / Brake Caliper with 4 piston Rear rotor: 345x24mm / Brake Caliper with 2 piston S2NHA Variant 2: (all 335i/d Version, Europe Version of 325d, 328i, 330d) Front rotor: 370x30mm (Millimeter) / Brake Caliper with 4 piston Rear rotor: 345x24mm / Brake Caliper with 2 piston Option of Dimple drilled and slotted rotor: For all the original brakes with 340mm rotors, one can buy aftermarket original BMW replacement brake rotors in dimple drilled and slotted flavor. For the factory upgrade with S2NHA M Sport Brakes (blue colored) one can also buy aftermarket original BMW replacement brake rotors in dimple drilled and slotted flavor. Available Front Size 340mm and 370mm (18" Wheels needed with 370mm rotor in Summer and Winter!!) Rear rotor: 345mm (all models) So and now what about the "M Performance Brakes"? For a "high power" car owner (Europe 328i, 335i, 330d, 335dx): Basically they are the same as if one would order the S2NHA option and then aftermarket change to the rotors to the BMW replacement brake rotors in dimple drilled and slotted flavor. For a "low power" car owner (models below 328i, 325d or US Model 328i): It's a much bigger upgrade. As they get 370mm front rotors instead of just a 340mm front rotors they would get by the S2NHA Sport Brake Option for those models. So if one is looking for dimple drilled and slotted front and rear rotors, and brake rotors with 370mm in front and 345mm in rear. M Performance Brakes is your choice. They come in different caliper colors: Yellow, Orange, Red M Performance Brakes need 18" Wheels in Summer and Winter M Performance Power Kit (for 330d and 335dX only): Needs a brake upgrade to S2NHA M Sport Brakes or 18" M Performance Brake! Source http://www.realoem.com/bmw/ Please feel free to comment upon found errors. Cheers Last edited by oceanview; 04-20-2024 at 08:10 AM.. Reason: Note: Excel Table Link fixed |
07-17-2013, 12:33 PM | #2 |
12
Rep 198
Wow, so from what I see if I have a 335i with 2NH, all I have to do to get the exact same configuration as the $3k M Performance Brakes is to upgrade my rotors to the slotted ones. Just checked the prices online and this would be a grand total (2NH + then the rotors) of $1,600 or something. That's a lot of savings! Then of course you could sell you old rotors as new or lightly used and make this even lower. It's hard to believe but why not.
(This is USD prices) |
07-17-2013, 01:57 PM | #4 | |
207
Rep 603
http://ebcbrakes.com/product/3gd-sport-rotors/ In racing situations certainly they are bether. But also in normal street conditions I see some advantages: - much bether braking in wet street conditions (braking in heavy rain conditions) - drinving downhill with heavy load or a hanger (where regular Brakes tend to brake fading) It's not only about the rotor, also the brake pads are very important to reach a high friction in cold and hot brake situations. So you need to look at brakes as a system! |
07-17-2013, 02:07 PM | #5 | |
207
Rep 603
If you like the blue calippers together with your car Body color, go for it. You'll need 18" Wheels with those Brakes! And don't expect to get too much for your "old" rotors. See some other offerings here in this Forum. |
10-29-2013, 07:51 AM | #6 |
31
Rep 194
Hi oceanview ! This is a great thread. Thx so much for the detailed advice.
I've ordered a 428i with the M sport blue brakes. I was thinking of changing the factory discs with the drilled and slotted M Performance discs. Just confirming that this is okay. Also the wheels will be 19". The brakes should be ok with the wheels right?? I've heard that the drilled and slotted discs are quite squeaky. Is that correct? Thx in advanced. |
10-29-2013, 07:17 PM | #7 |
207
Rep 603
Hi
The factory option "S2NHA M Sport Brakes" on a 328i will change your front rotor size to 370x30mm. So they are the same size as the 18" M Perfomance Brakes. Yes you can change those rotors to 18" M Performance Brake Rotor in dimple drilled and slotted flavor. Front rotor: 370mm = Part Number 34 10 6 797 603 Rear rotor: 345mm = Part Number 34 20 6 797 600 Yes those rotors make some noise, but it's not squeaky at all. The sound is more a "schhhhhhhhh" not a "eeeeeaaaaaak" You can also hear the noise when drinving with open windows and not pushing the brakes. You need at least 18" wheels (also for winter tire Setup. Probably Overkill Australia :-) ). I heard not all 18" wheel will fit, so check before buying. Anyway your going to 19", that's fine! My Combo is with 20" for Summer and 18" for Winter. On the pic you see the 20" 405M wheels. http://www.f30post.com/forums/album.php?albumid=8979&pictureid=47196 http://www.f30post.com/forums/album....ictureid=47197 |
10-29-2013, 07:55 PM | #8 | |
Law Enforcer
25021
Rep 22,269
Drives: '22 Chalk Gray Porsche C2S
10-29-2013, 08:31 PM | #9 |
1125
Rep 2,564
Is the weight listed for the 335 2NH option correct? More than 50 percent heavier than the slotted versions and the 1" smaller non 2NH version? Something doesn't seem right. For the non 2NH brakes, the slotted versions are only .1 lb lighter. I'd imagine something similar on the 335 2NH version.
10-29-2013, 08:56 PM | #10 | |
Law Enforcer
25021
Rep 22,269
10-29-2013, 09:22 PM | #11 |
31
Rep 194
[QUOTE=oceanview;14893074]Hi
The factory option "S2NHA M Sport Brakes" on a 328i will change your front rotor size to 370x30mm. So they are the same size as the 18" M Perfomance Brakes. Yes you can change those rotors to 18" M Performance Brake Rotor in dimple drilled and slotted flavor. Front rotor: 370mm = Part Number 34 10 6 797 603 Rear rotor: 345mm = Part Number 34 20 6 797 600 Hey Ocean ! Thanks for such the quick reply. Just checking for a 328i or 428i the rear rotor part nuber is 34 20 6 797 598 rather than 34 20 6 797 600. Is this correct ?? 34 20 6 797 600 is for ? 335 or 435i ?? I am not sure Thx Steve |
10-29-2013, 09:31 PM | #12 |
44
Rep 349
+1
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
10-30-2013, 05:22 AM | #13 | ||
1125
Rep 2,564
10-30-2013, 02:55 PM | #14 | |
207
Rep 603
[QUOTE=secret agent;14893707]
Please ask your dealer. Last edited by oceanview; 10-30-2013 at 05:31 PM.. |
10-30-2013, 03:01 PM | #15 | |
207
Rep 603
34 10 6 797 606 Standard rotor 370x30mm (S2NHA Standard rotor for 335i) 16.50 Kilogramm / 36.4 Pounds seems quite high compared to the other 340 or 370 Rotors. Maybe someone has another source to check. |
10-30-2013, 04:34 PM | #16 | |
Law Enforcer
25021
Rep 22,269
11-01-2013, 04:48 PM | #17 |
13
Rep 149
Drives: 2016 340ix Msport mppsk
Boy I'm glad I found this thread. I was thinking of buying a pair of M-Performance brakes off ebay to upgrade my F30 but I just dropped $1500 on new winter tires and they're 17's that would have sucked lol. Definitely not worth buying 18" winter and spending another $1500. Thanks.
11-02-2013, 05:11 AM | #19 | |
207
Rep 603
However I strongly recommend not to do that unless checked with your dealer! It could be that this could badly influence the brake balance and other security features like cornering brake system, ABS, Stability control.... Sure it could work, as models below 328i/325d upgrading to S2NHA will get: Front rotor: 340mm / Brake Caliper with 4 pistons Rear rotor: 345mm / Brake Caliper with 2 Pistons But I don't know if any programming needs/could be done with such a Setup. Again, check with your dealer! Last edited by oceanview; 11-02-2013 at 05:21 AM.. |
11-02-2013, 05:39 AM | #20 | |
207
Rep 603
Good Point. I outlined now the need of 18" wheels in my OT!
Anyway, ordering the "Sport Pack" option already includes 18" wheels. So one could use those for winter setup and get yourself some good looking 19 or 20" for summer Setup :-). (That's what I did) Quote:
11-07-2013, 01:11 AM | #22 | |
179
Rep 1,044
