Did I get fleeced?
06-25-2013, 09:47 AM | #1 |
Irish
35
Rep 100
Did I get fleeced?
So my car was showing the symptoms of bad valve cover gasket. I brought it to a non BMW shop that does bmw's, merc's, etc. and they changed the gasket. The car is still leaking oil and showing the same symptoms. They charged me $900 to do the job (car is 2007 e92). So I brought the car back and they looked at it and without taking the valve cover back off they said that the valve cover is warped and now it was going to be $1100 to fix that!
I did some research online and found this in a forum thread: The issue with BMWs valve cover gaskets is on the back of the head oil seeps out because gasket doesn't seal perfectly there. To solve this apply a small amount of ultra copper silicone gasket maker to the halve moon shaped cutouts on the back of the head. BMW does not say this is necessary when replacing the gasket but from experience and from what others have told me this is the best way to prevent seeping oil. Ive done this to all the BMWs I've replaced valve cover gaskets on. It seems to me that the shop I brought it to maybe just didn't do as described above. I don't know how they can tell me the valve cover is warped without taking it off? When I asked them to show me that it was warped they said that it's impossible to show that its warped?? So I said how do you know its warped then? Any advice on what I should do? I am out $900 and still have a leak. And I was going to do the job myself I probably would have done a better job.... |
06-25-2013, 09:52 AM | #2 |
1204
Rep 2,818
You would have been better off going to a dealership and paying the $600-800(depending where you live and how much they feel like gouging you) that they charge for that job.
If it's truly warped they shouldn't charge you additional labor, just the new valve cover itself since they didn't truly diagnose your vehicle correctly.. |
06-25-2013, 11:35 AM | #4 |
Hi Hater
15
Rep 424
heres a few questions that may be of help
do they charge by the hour? if so how many hrs did they quote for the labor? are they licensed? did you sign a written estimate or work consent form? because this seems like a rip off to me, they over charged significantly to begin with but it also seems as if they may have not done the job properly, i would state the request to the shops owner or manager and demand for it to get fixed tell him otherwise you will be taking your request to the Bureau of Automotive Repairs. If the issue isnt resolved i would contact BAR(bureau of automotive repairs) and file a formal complaint, they will come knocking on these guys doors and will be looking for all the proper documentation and paper trail of the job, they will open an investigation and if the shop is violating ANY automotive repair laws they will get stripped of their license. The most common mistake they make is not giving out written estimates which in most states is in direct violation of some auto repair codes. I doubt it will go as far as that because if this shop is as illegitimate as they sound last thing they will want is for BAR to be going thru their stuff. |
06-25-2013, 10:23 PM | #5 | |
103
Rep 2,783
06-26-2013, 10:17 AM | #6 | |
Hi Hater
15
Rep 424
Automotive repair places laugh at being threatened by the BBB because all they can do is pretty much give them a bad review BAR can shut them down edit: The Florida Department of Agriculture and Consumer Services is actually who regulates repair shops in Florida. http://www.800helpfla.com/motorveh.html |
