Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Changed Transmission fluid, got 5 qt's out, only 4 in?
      06-17-2013, 11:42 AM   #1
ksalih
ksalih's Avatar
71
Drives: 2018 M2 LCI
Hey, changed my transmission fluid in my ZF tranny 335i this weekend. Was only able to get about 4 quarts in, but drained 5-5.5 qts. I shifted the gears, followed the DIY correctly. I should have been able to get more than 4 quarts in the fill hole before it started pouring out.. Is it possible my fluid was too warm when I was filling it..thus causing expansion and for it to start pouring out?
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      06-17-2013, 01:30 PM   #2
biz77
174
Drives: 2021 X3 M40i
Car was level and engine running while filling?
      06-17-2013, 02:55 PM   #3
ksalih
ksalih's Avatar
71
Drives: 2018 M2 LCI
Yes and sort of..car was not running while I filled it with fluid, but I had it running until fluid as @ temp, went through the gears etc, then filled it. I drove it home ~10 miles, will check again while it's cold to see if I can fill up with another quart.
      06-17-2013, 03:16 PM   #4
Chriztofor
Chriztofor's Avatar
103
Drives: '06 325i and '13 X5
You have to check the trans oil when the engine is running and the oil is warm. Check on here for a DIY on your 335 trans to confirm.
      06-17-2013, 03:19 PM   #5
ksalih
ksalih's Avatar
71
Drives: 2018 M2 LCI
Correct, however checking the fluid while running I believe is to ensure the fluid is @ temp. However, letting it run and going through the gears should give the same effect, thus rendering the idea to keep the engine running unnecessary. I could be wrong?
      06-17-2013, 03:24 PM   #6
Chriztofor
Chriztofor's Avatar
103
Yeah it needs to be running. Here is the DIY for my 325, but again check for your 335.
"10) After about 8 minutes (you do not have to shift through the gears all this time), with the car still running, I placed my hand on the transmission pan, it was warm therefore it should be between 86 -122 degrees F. I opened up the fill hole and no oil was coming out." http://www.e90post.com/forums/showthread.php?t=367729
      06-18-2013, 02:25 PM   #7
biz77
174
Car MUST be running to properly fill the transmission.
      06-20-2013, 06:47 PM   #8
JunkStory
160
Drives: E92 M3, 8V RS3
either way you won't ever be able to fill up the same amount you got out. At the factory, the oil was poured from the top, but we don't have the luxury of doing that. We can only pump oil from the bottom drain hole.
I followed all procedure, had oil warm, car was running, and even angled the car at a particular angle that would maximize the amount of oil I could pump in, but still pumped in less than what I got out.
      06-20-2013, 07:59 PM   #9
RemovedUser
Guest
n/a
Drives:
Car has to be running and level and between a certain temp range.....
Read the DIY, its a 5k+ transmission don't get it wrong, you can also search some of my previous posts where I have gone into extreme detail about the procedure.
      06-20-2013, 09:35 PM   #10
ritjeff
ritjeff's Avatar
Drives: E90 LCI 335xi
The sump sucks the fluid up when fairly hot, so if it's not at operating temp, you can't get enough in before it flows out. If you have a good way to measure the correct amount, you can jack up one side and cheat. Otherwise, you need it almost scalding hot. As soon as it starts to cool, it comes down into the pan. You may want to use a thermometer.
      06-21-2013, 12:39 AM   #11
kenmasters
Drives: 335
Hot scalding oil. Filling up while the car is on and on stands. I would much rather have a shop do this for me. But I don't trust that a shop would follow the correct procedure either.... ?
      06-21-2013, 05:04 PM   #12
ritjeff
ritjeff's Avatar
Some certainly do not
