Same Old Battery Dilema
06-16-2013, 09:48 AM | #1 |
Rep 41
straight to the point battery had problems after coming from body shop went to orielly's auto part store to get it tested. It tested bad 3 times bought a battery from orielly's specs of battery below.
900 cca 1080 ca Main question is from personal experiences what happens if i just replace the battery and do registration on Tool32. Without the programming because Google has no clear reference or step by step write up of the programming. |
06-17-2013, 07:03 AM | #2 | |
535
Rep 1,873
06-17-2013, 08:50 AM | #3 |
Rep 41
i had been researching and found so many post on when you replace a oem battery with a aftermarket with more cranking amps you had to first program CAS and then register the battery.
06-17-2013, 10:47 AM | #4 | |
535
Rep 1,873
Do you have an Ah rating on your new battery? I believe most factory batteries are in the 90Ah class. I think the next highest coded option is 110Ah (but that's just from memory - search will say for sure). Registration is a must, but coding might be optional depending on how big a change. |
06-20-2013, 07:06 AM | #6 |
535
Rep 1,873
Although "the Internet" shows formulas on how to calculate Ah from CA or CCA, they aren't really related in any way. There may be some averages based on typical automotive starter batteries but...
My suggestion would be to use some search engines and your specific battery model# (especially if you can find out what it ACTUALLY is - there are really only about 4 companies who actually make the batteries that everyone else slaps their label on). It's probably one of Exide, East Penn/Deka, Johnson Controls. |
06-20-2013, 11:48 AM | #7 |
18
Rep 122
06-21-2013, 08:14 AM | #8 |
535
Rep 1,873
06-21-2013, 10:08 AM | #9 |
41
Rep 146
Registration is definitely needed and so is coding. Google has plenty of perfectly clear instructions, just look harder. I was able to learn how to code for my car within a week of buying it and code the car and then registered the new battery as soon as my cable arrived. Toolset32 can register your battery and you can use NCSEXPERT to code for the new Ah values (CCA is not ever coded) in CAS=>KLASSE_BATTERIE.
If I were you, I wouldn't be messing around with some aftermarket battery from O'Reilly's. Issue is that those batteries never list their Ah value that you need to code, they sometimes list RC or Reserve Capacity, but that is not the same thing. Even if they listed the Ah values, BMW's only take these: Code:
80ah 80 ampere-hours 90ah 90 ampere-hours 110ah 110 ampere-hours 70ah 70 ampere-hours 55ah 55 ampere-hours 46ah 46 ampere-hours 70ah_agm 70 ampere-hours (agm) 90ah_agm 90 ampere-hours (agm) 60ah_agm 60 ampere-hours (agm) 80ah_agm 80 ampere-hours (agm) |
06-22-2013, 10:38 AM | #10 |
Rep 41
i took to dealership they have no problem with the O'Reilly's battery and ran the battery registration and while doing electronic diagnosis So now i have problems with water pump cutting on while the engine is off which the service advisor says he has never seen that in happen before. thanks for all the advise
06-22-2013, 09:45 PM | #11 |
106
Rep 728
Yes don't worry about O'Rielley battery. I'm using the Walmart one and haven't had a problem in 2 yrs. I can even watch 2 movies at a drive-in theater on a full charge so I'm sold on not going with expensive battery replacements.
Keep in mind though that I periodically trickle charge my battery to maintain it in optimal condition.
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
