CDV Bleed Question
06-03-2013, 08:48 PM | #1 |
1056
Rep 1,459
Guys,
I have a question after reading several DIY's on removing the CDV. How do I bleed the line. Please be very specific. Do I loosen the nut then go inside the car and pump the clutch a few times, then go back to the nut and tighten it again? How do I know when I've cleared the line? If I loose some fluid from the CDV do I add more fluid to the brake fluid reservoir? Which kind should I buy? I've never even changed my oil before so I'm quite nervous. |
06-04-2013, 07:33 AM | #2 |
General
17315
Rep 18,737
You bleed the line the same as would bleed the brakes. You need to follow one of three methods:
Use a pressure bleeder that pressurizes the brake fluid reservoir and then open and close the bleed valve on the slave cylinder. Attach a clear tube on the bleed valve and put the other end in a jar with a bit of fluid in it so as to not let air back in the system Or, use another person to pump the clutch pedal while you open and close the bleeder valve. The valve should be opened while the other person slowly presses the clutch pedal, which will bleed the air out of the line and then close the valve while the clutch pedal is still in the down stroke. Use the same clear tube setup as above. Make sure the person pumping the pedal does not bottom-out the clutch pedal. Or get a vacuum canister (oil extractor) and attach it to the bleed valve to pull the hydraulic fluid through the slave cylinder. Any of these procedures takes very little fluid to move through the system the get the air bled out. |
06-04-2013, 09:38 AM | #3 | |
1056
Rep 1,459
06-04-2013, 09:48 PM | #4 | |
General
17315
Rep 18,737
When you open the system to the atmosphere, like when you disconnect the line to remove the CDV, the vacuum in the system is broken and air is allowed into the line since air always fills a void (vacuum). The best way to minimize the amount of air introduced into the system is to clamp the hydraulic line at the very end with a hydraulic line clamp. Once you reattach the clutch line, you then apply pressure to the system by either applying pressure to the hydraulic oil in the brake fluid reservoir (it feeds the clutch master cylinder), or you pump the clutch pedal, or you pull a vacuum on the line. Once the air goes out of the line you close it. Use clear tubing to see the air bubble move out of the bleed nipple, then close the bleeder valve. |
06-05-2013, 06:36 AM | #5 | |
1056
Rep 1,459
06-05-2013, 06:53 AM | #6 |
General
17315
Rep 18,737
No catastrophic event. But you may notice a spongy, non-direct feeling pedal for a bit. When I took my valve out, I did not bleed the system, I never noticed an issue.
06-05-2013, 07:09 AM | #7 |
38
Rep 627
I also have some questions about this procedure. I bought a Motive brake bleeder kit to do my brakes. From what I read you supposed to bleed the brakes by opening the bleeder valve at each caliper. Where is this same brake bleeder valve that you're talking about?
