Help With Valve Cover
05-30-2013, 10:41 AM | #1 |
Rep 4
While Replacing the valve cover gasket on my e90 328xi (N51 engine) the opening for the "Vacuum pipe" (part# 11157547820) attached to the valve cover broke off. The Vacuum pipe connects from the valve cover to the "Connector" (part# 13717537502) which is a part of the air intake muffler. A) Could I seal the openings on the valve cover and connector to prevent leaks? B) Use adhesive to reattach the broken nipple? or C) Am I going to have to replace the valve cover?
I did not break the large vent hose in the rear of the valve cover. Just the opening for the vacuum pipe below Spark plug six. PLEASE HELP |
Tags |
vacuum leak, vacuum pipe, valve cover, valve cover gasket |
