inner tire wear & alignment specs
05-15-2013, 08:34 AM | #1 |
32
Rep 160
Had a constant humming noise, thought it was a wheel hearing upon getting it on a lift it became obvious both front tires had excess inner tire wear. My buddy had a little time to get it on his alignment rack to check if it was within spec. We didn't have any weight to put in the front/rear or truck like the 'Hunter' alignment system suggested so not sure how much that affects the alignment specs we got?
FRONT LEFT -.8 Camber 7.2 Caster .09 Toe FRONT RIGHT -.3 Camber 7.5 Caster -.02 Toe Everything is pretty close to spec, front left camber is a little low (again not sure about not having weight in the car if that affects this). Tires are Bridgestone RE050A's. |
