BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Wobbly at about 150mph
      05-06-2013, 04:00 PM   #1
cleex024
104
Drives: 2008 BMW 335i Coupe
hey guys just wondering if any of you get a little wobble at about 150mph? Ive been doin some runs to about 150 and it gets a little wobbly...when i got an alignment went with front : -2.2 camber and 0 toe... rear : -1.8 and .05 total toe in.
wanted to go very neutral but i think this might be whats causing the straight line issue.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      05-07-2013, 02:03 PM   #2
mike-y
just another bmw douche bag
195
Drives: 1.9L of fury
typically, zero toe will give up some high speed stability for better turn in abilities. but at those speeds, aero (or lack of) can make a big difference also.
      05-07-2013, 02:10 PM   #3
cleex024
104
thanks for responding but i did get an alignment after putting in my rear upper camber arms and got an alignment with a little toe in about .05-.1 front and rear and there is a lot more stability so i guess that is the answer.
BUT after the couple runs to 140 i came to a stop light and accelerated hard and bam my camber arm stripped off and almost crashed...thankfully this didnt happen during my high speed run or i might be dead.
drove home extremely slowly and found out that i only had 1 thread into the tubes lol and it stripped out. gonna wait for longer tubes to retry this lol.
      05-16-2013, 05:16 PM   #4
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
at those speeds anything can make it just a hair squirrelly. I was just at 140 a week and a half ago, and as I turned in I was only about getting the car settled in and straight. 150 is moving.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
      05-16-2013, 05:18 PM   #5
infidel335
infidel335's Avatar
29
Drives: 2009 335xi
Aero is huge at those speeds! What have you done to the car in that regard?
335xi: JB4 G5 | KW V1s | muffler delete | BMS DCI | VRSF 7" FMIC | VMR v703 18x8 | and your mom
      05-16-2013, 07:05 PM   #6
cleex024
104
in the aero department. ..guess I gotta look into it... but then again is not likei feel like the car is going to spin on me
