TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Tire Temps
      09-13-2007, 12:18 AM   #1
roy@gambitmotorsport
Something Else
roy@gambitmotorsport's Avatar
24
Drives: '07 335i coupe 6MT
Tire Temps
I have a 335i coupe sport package, manual transmission, Bridgestone run-flats. My tires are at 32psi front/35psi rear. I recently drove some twisties for more than 10 miles, sat behind a slow truck for about a mile, then pulled over for lunch and measured my tire temps with a MicroTemp Pro. I wrote down the variations, rather than the exact temps, as I was damn hungry. But, I double-checked them all. Here is what I got:
Front - inside cool, mid hot, outside medium
Rear - inside hot, mid med, outside cool
These were all within say 140 to 150 degrees, so hot and cool being 10 degrees apart.
Questions:
- Did I not even get near warming up my tires?
- Does the data show that the rears are cambered more than the front?
- Should I change pressures?
      09-13-2007, 09:56 AM   #2
leftcoastman
52
Drives: 335i
Rear does have more NEGATIVE camber, so it makes sense. Your fronts are a bit odd, as my outsides get toasting hot due to the neutral/pos camber.
Try this exercise on a track. I'd be curious to see the results. I should show you a pic of my front tires. From afar, my tires look like slicks. Up close, you can see tread increasing as you look towards the inside.
      09-13-2007, 11:36 PM   #3
Something Else
24
Will definitely do that. Just finished break-in, so I'm looking at something in the near future.
      09-13-2007, 11:50 PM   #4
S4to335
431
Drives: 2014 Audi A4 / 91 Track Miata
To be honest..I dont think you can tell much by running street tires on a canyon run and then checking tire temps with a pyrometer...now if you were on full race tires..or even R compounds...and on a track during a test day...then you could tell something. General rule I go by is...If the center is too hot...you have too much pressure. I try to hit 40-41 lbs hot with my R compounds when I am on the track...and for right this second with my existing setup...I lower pressures right after I get off the track to try to maintain that 40-41 lb pressure range.
Having a pyrometer if you are not tracking a ton..IMHO...maybe a bit of overkill.
When I raced in Spec Miata...I didnt even have a pyrometer...however a few other fellow racers did. I was also not a front runner.
Car is now gone .... :-(
      09-14-2007, 10:30 AM   #5
elbert
digging for gold
elbert's Avatar
Drives: Ford Tempo GL
What kind of pyrometer did you use, infrared or probe? You want to use a probe type because it can measure the internal core temp. An infrared pyrometer measures only surface temps.
      09-14-2007, 10:36 AM   #6
S4to335
431
I have seen both...the infrared is not that far off the probe type unless you are a team manager for a race crew. :-) Some of my friends have the infrared type...guys who track a lot.
      09-14-2007, 12:14 PM   #7
Something Else
24
No doubt. I plan on tracking it and on changing tires in the near future. Just playin' around with the new toy.
      09-14-2007, 12:15 PM   #8
Something Else
24
It's infrared.
      09-19-2007, 11:46 AM   #9
elbert
digging for gold
elbert's Avatar
ok, keep doing it the wrong way
