05-03-2013, 03:15 AM | #1 |
Rep 26
Coding newbie : a few questions
Hi all,
Let me introduce myself first, i'm a Belgian, currently driving a C200 (bah, don't like it anymore) I've been almost "living" on this forum since i ordered my new F30, sapphire Black. (And wow you guys are all pro's when it comes to coding ) I've got the options (specific for multimedia etc..) 6NH 609 PRO NAVI (so that would mean that i have the COMBOX right? ) 6AB BMW TeleServices (no idea what it is) 6WA I'm looking for two specific things to code, and since i'm new i don't know if it is possible and i do not find the exact statement saying it is possible. 1) Can i enable Internet on my iDrive 2) Can i enable BMW Apps on my iDrive 3) Can i control spotify / play spotify with USB if i code to advanced bluetooth? One post says you can, the other says you can't .. i don't know anymore Last but not least.. if i enable VIM, will the navigation still work? (with my current C-Class, it stops working since it has something to do with a velocity meter being overruled) I thank you very much.. and looking forward to contribute! Best regards, Nicolas
F30 320d Efficient Dynamics
Modern Line - Exclusive Package - Connectivity Package (PROGPS / 6NH - Sunglass - Oyster Leather / Accent Swartz |
05-03-2013, 07:02 AM | #2 |
35
Rep 239
If you code the advanced bluetooth then you should be able to use spotify with bluetooth.
Coded bluetooth ahould be the same as the factory bluetooth. Ramon (Nederland) |
05-03-2013, 07:30 AM | #3 | |
Rep 26
Thank you for the update. Can you play spotify trough USB?
05-05-2013, 11:05 PM | #5 |
General
10413
Rep 40,650
Drives: 2018 Alpina B6 650ix GC
1) On the F10, it is possible to code Internet / BMW Live with 6VC Combox and 609 Nav by disabling BMW Assist and using a fake VIN with factory 614 Internet written to Combox, and then updating BMW Services. I detailed that process here:
2) As for 6NR BMW Apps, you have the needed 6VC Combox, and 609 Nav but you need to buy a 9C FSC Code and Import and Activate it in the CIC head unit. This will get you the Apps and Music Streaming. I have done this in my car. If you also want the iPod Out GUI and Video though, then you also need additional hardware. You would need to either retrofit 6NF Base Plate, and run FBAS video line from it to the CIC, or you could replace the factory 6FL USB Aux-In Port with the USB AV-In port from the Mini Cooper, and run the FBAS Line from it to the CIC. 3) Change VO from 6NH to 6NK, and VO Code Head Unit and Combox.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
05-08-2013, 08:46 AM | #7 | |
Rep 26
First of all : i'm addicted to fries, so you can count on it! 2nd of all : i have to wait until july to do some coding.. doing research at the moment so i don't waste any time when i actually get my car I will send you a PM so we can keep in touch!
05-14-2013, 08:58 AM | #8 | |
Rep 11
Tried to change the VIN as apecified above on my F30 but every time get stuk when coding FDL code CMB_MEDIA using the new VIN. I'm getting the below error: Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. [C205] ExecutionID=2013/05/14-15:36:39.709 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [CMB_MEDIA - 36] prepareECUforCoding started [CMB_MEDIA - 36] prepareECUforCoding finished [CMB_MEDIA - 36] authenticateECUforCoding started [CMB_MEDIA - 36] authenticateECUforCoding finished [CMB_MEDIA - 36 - cafd_000005b6-004_002_010] Transaction type: cdDeploy; Message: TA started [CMB_MEDIA - 36 - cafd_000005b6-004_002_010] Transaction type: cdDeploy; Message: TA finished [CMB_MEDIA - 36] finalizeECUCoding started MCDDiagService<id=80649, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : requestOutOfRange, link=CMB_MEDIA_36_ETHERNET> [CMB_MEDIA - 36] finalizeECUCoding error [Exception - CMB_MEDIA - 36] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; ECU: CMB_MEDIA_36_ETHERNET severity: ERROR [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207] TAL execution finished. Duration: "8s". [C206] Abarbeitung beendet Transaktions-Report: Aktion: Codieren CMB_MEDIA [36] cdDeploy ProcessedWithError cafd_000005b6-004_002_010 Processed Any idea what is going wrong and how to fix? Used a VIN that has 6NL, 612, 613 and 614 as options. Additionally BMW Internet shows a error "Not supported in this Country" BMW live is currently showing a "Page load error"message. Will try again tommorow. M Thanks, Martin |
05-14-2013, 09:10 AM | #9 | |
General
10413
Rep 40,650
This error looks like the standard error when using new PSdZdata versions with old version of E-Sys 3.18.4. What versions of E-Sys and PSdZData are you using?
05-14-2013, 12:29 PM | #10 | |
Rep 11
FAKE_VIN used (googled):XXXXXXXXXXJ271341 Are you able to FDL Code CMB_MEDIA normally? Yes What versions of E-Sys and PSdZData are you using? E-Sys:v3.22.5 ; PSdZData:v49.2 |
05-14-2013, 07:20 PM | #11 | |
General
10413
Rep 40,650
http://www.bimmerfest.com/forums/sho...5&postcount=45
06-12-2013, 05:57 AM | #12 |
Rep 6
Im also looking to get the 'Internet' option working.
Iv managed to get it to show HU_CIC 3003 > ONLINE_BROWSER = beide_aktiv but get the mesg - it is unavailable in my country and there are other services available. have the following - F10 530D 10/10 609_NAVIGATION_SYSTEM_PROFESSIONAL 612_BMWASSIST 616_BMWONLINE 6AA_BMW_TELESERVICES 6VC_CONTROL_COMBOX Im not to confident or sure how to do this VO change as per 'shawn's response' is there a more step by step process please. much appreciated! |
06-12-2013, 09:10 AM | #13 | |
General
10413
Rep 40,650
http://www.f30post.com/forums/attach...4&d=1338274757
10-31-2015, 01:23 PM | #14 |
Rep 14
Hi Shawn,
I followed your instructions above to activate on an early 2013 328i F30, along with some info I've found elsewhere. My iDrive doesn't give me the option of selecting "data transfer" under bluetooth settings unless I set CMB_MEDIA SIM_ENABLED_MB > Csim as well as the PAN and DUN to aktiv in both the HU_CIC and the CMB_MEDIA Doing that, combined with most of your steps, I get to the "update Services" step. Update services is greyed out and unselectable. Everything looks like it should work. However, my iPhone never indicated a connection to the hotspot.I say most of your steps because I couldn't add 644 to my VO and I had no 612, 633, 639 to remove. I did find a vin with 614 authorized, and was able to code that vin to the cmb_media but that however doesn't seem to be the issue. I checked with my computer and the phone hotspot does work via bluetooth. If I try BMW Live or Internet I just get a message that say "Please activate data on your bluetooth device..." It's apparent that the vehicle is not attempting to connect via bluetooth even though the option is checked for the phone. It feels like I'm very close, but I can't get past this hurdle. Any help would be great! Thanks in advance! |
03-06-2016, 03:34 AM | #15 | |
Lord Scrip
1812
Rep 3,012
Drives: 2011 M3 Coupe
03-06-2016, 08:22 AM | #16 | |
General
10413
Rep 40,650
That said, you should not be having to FDL Code SIM_ENABLED_MB. For this to work, Telematics needs to be completely disabled, as the Head Unit can only be configured to use either Car SIM or Phone SIM, but not both. This is accomplished via the Bluetooth Option Code and VO Coding. You do not have 644 as you probably have 6NL, in which case you should try same process as me, but using 6NK instead of 644.
07-19-2016, 10:49 AM | #17 | |
12
Rep 211
not if you can help. I took a year trying to modify 6AL ( bmw live). but that I do wrong.. you think I can make a Fakevin. My vin F329413. in advance.thanks |
07-19-2016, 10:52 AM | #18 |
General
10413
Rep 40,650
You have 606 Business Nav, which in your car is likely ENTRYNAV Head Unit, and I have no idea if 6AL is even a valid Option for it.
07-21-2016, 03:12 AM | #19 |
12
Rep 211
07-21-2016, 07:02 AM | #20 |
General
10413
Rep 40,650
Yes. Fake VIN is used only temporarily to Provision the car for the service, and then original VIN restored.
