BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Run different tires?
      04-23-2013, 03:29 PM   #1
SyL3nTFoRcE
64
Drives: 2008 335xi
Is it possible to have two different tires
im looking to buy stock e46 wheels for my e90 but he has two continentals in the front and 2 hancooks in the rear, all the same tire size though.
Can i run that setup on my 328xi?
      04-26-2013, 06:33 PM   #2
amr_e90
amr_e90's Avatar
203
Drives: e90 335xi 6mt
you need too make sure the sidewall wear percentage is even or it will fool around with xdrive system
14 M5 / comp / CCBs / alpine white
PG intakes
Evolve tune
Switzer exhaust
Fabworx pipes
      05-10-2013, 06:07 PM   #3
pitbulls5n6
Drives: BMW
yea i had that set up on my e90xi ..no problem at all
      05-18-2013, 07:52 AM   #4
abrahambeckers
Drives: ALTO car
I went in to replace my car front two tires because it was causing major steering wheel vibration. In some cases A tire has been discontinued then you may be forced to do it. If you uses to mix tires they should be the same type of tire with the same service description.
      05-18-2013, 09:57 AM   #5
zipstic
484
Drives: 2008 e92 335xi
2008 335xi Coupe  [10.00]
Make sure you do this.
Also consider that if you have different tires on front vs rear the overall performance and handling is going to change and the car may not handle as you would expect in emergency situations (hard braking, aggressive turning to avoid another car, etc.) This is an extreme example, but if you have snow tires on the front and slicks on the rear in the same size the handling is going to be compromised.
