F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Valentine V1 "Hardwire" DIY with remote display and SAVVY
GetBMWParts
      04-19-2013, 04:10 PM   #1
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
So, it's not a true hard-wire b/c I didn't wire it in - instead, the V1 get's it's power off the OBDII port using the Savvy module. This module transmits speed from the OBDII port to the V1 and auto-mutes warnings under a pre-set speed (that you set). I also have the remote display for the V1, and that's really what I wanted to show here.
First goal - find a place for the V1 where it was level and could see out the front and back (for laser). Also I didn't want to mount it to the windshield so people standing outside the car wouldn't see it (cops, thieves etc). I chose hanging it off the visor. It's far enough back that you really have to make an effort to see it through the window
To facilitate it being level, I put a number of layers of 3m double sided tape to the top of the bracket to hold the visor down just a tad, and ran the cable across the back of the visor to the pivot point
From there I ran the cable behind the weatherstripping on the door (just pulled it back a little and stuffed the cable in) then popped the little plastic piece off the door jamb and was able to get all the way down to a whole next to the obdII port. There I plugged in the Savvy, stuffed the little dongle up into the opening and was good to go.
Problem was, the display on the V1 was too far back to easily see without really taking my eyes off the road - in comes the remote display
I chose to mount the remote display left of the instrument cluster behind my registration and inspection stickers - but I didn't want to stick anything to my car. I decided to fab up a quick bracket that would slip between the trim pieces and hold the display down.
I started with some 0.025 aluminum sheeting, cut a 3/4" strip off it then filed and sanded it down to take the sharp edges off.
The plan was to bend an angle into it and cut that off so I could slip it down between the a-pillar and the dash - creating the angle
Ready for testing
Test fit
Now to make it black like the dash
All done - way better having the display out there. I don't need to take my eyes off the road to see where the warnings are coming from
No permanent mods to the car and everything is concealed and firmly in place - side note, the Savvy is neat - really nice when driving around here <45 mph not having to mute all the grocery stores and gas station false alarms
      08-20-2013, 09:31 AM   #2
DVC
Diligentia Vis Celeritas
DVC's Avatar
558
Drives: 335i
Nice job on this install. I am planning to do roughly the same, except I'll locate the V1 on the windshield tucked behind the passenger-side of the rear view mirror. Also I was planning to just stick the concealed display to the dash with 2-sided tape, but your idea with the aluminum piece is a good idea; I may opt for that approach as well... where did you get the piece of aluminum?
Regarding the SAVVY, is it just a plug into the OBDII, or is there a "box" somewhere that you have tucked out of sight? Is there plenty of room behind the OBDII port panel to tuck-in the SAVVY connection and the RJ11 connections?
Ahead of the curve for specF30
      08-20-2013, 12:16 PM   #3
utenigma
162
Home Depot - just a thin sheet of aluminium I cut into a strip with my table saw
It's an OBDII connector (right angle) with about a 6 inch lead that goes to a little distribution box with two connectors on it, one for the V1, one for accessories (remote display). There's a square hole next to the OBDII port under the dash that allows for easy access to run the cable up. There's plenty of room behind the dash and the panel in the door frame lets you get to it.
      08-20-2013, 01:05 PM   #4
DVC
DVC's Avatar
558
Drives: 335i
Perfect... thanks
      08-21-2013, 01:55 PM   #5
N3M35IS
Team Nemesis
48
Drives: 2020 X3M COMP
Nice... i have the same setup in mine... but i just installed double side tape on my display and stuck it on the dash lol
      08-24-2013, 08:57 PM   #6
quake
Drives: BMW X3
I used double sided tape as well... much cleaner IMO...
      09-04-2013, 06:55 PM   #7
Steve33
Steve33's Avatar
No_Country
50
Drives: 2018 SQ5
I'm almost identical except I managed to run the wire through the A pillar and headliner and suctioned the radar on my window
EDIT: and I got a mute button off ebay and stuck it on the steering column. You can reach the SAVVY from there with a little maneuvering
f30post
