Whirring Noise behind glove box
04-14-2013, 11:35 PM | #1 |
57
Rep 224
I've noticed that when I first start my car and drive around its silent inside the cabin, but just a little while later a constant whirring noise will start that originates from somewhere behind the glove box. The whirring will not stop until I turn the car off.
Any ideas? Last edited by Sample; 04-14-2013 at 11:37 PM.. Reason: clarification |
04-14-2013, 11:44 PM | #2 |
129
Rep 1,052
Blower motor is going bad due to rusty bearing/shaft. Use the search there is DIY that can help you replace. Some people also take it out and lube it with zoom spout turbine oil. Ace Hardware for about 2 bucks. I did it. Works fine. Takes about 20 mins.
Beats the $150 part.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
04-15-2013, 12:15 AM | #3 | |
57
Rep 224
Also, is this the DIY you're talking about? http://www.e90post.com/forums/showth...ghlight=blower Thanks |
04-15-2013, 01:16 AM | #4 |
55
Rep 474
Drives: 2009 328I E90
i have that same whine... but i notice it more on a decelleration when its quiet.
//// M3 Conversion front bumper //// Csl trunk lid //// mtech rear bumper //// resonator delete //// airrex digital air suspension //// megan camber arms //// godspeed toe arms //// Stance Wheels sf01 19x8.5 / 19x9.5 ////
instagram: thebernardexperience |
04-15-2013, 01:40 AM | #5 |
Rep 297
Typically a lot of members hear a slight fan noise behind the stereo or ecu bay. There is a small fan that calls the ecu that turns on from time to time and I have learnt to ignore it. But it's more of a fan mmmmm noise rather than a whine....
08 335i MSPORT & PR PKG/aFe St2 DCI/AA BOV kit +DP/SprintBooster Stage 2/Avant Garde 19 rims/ HNK V12 Pro Tires/BMS Wheel Spacers/ E92 M F n B kit incl blk kidney grills and sensors/Afe mach Exhaust. M3 skirts, DNA map 3
04-15-2013, 07:58 PM | #8 |
93
Rep 1,644
Yeah I hear that fan noise as soon as I get in my car before I even start it or even put the key in. I here it coming from the idrive area. It sounds like a fan. It does turn off after a while of sitting in the car without opening the door or moving any controls, but as soon as I open the door you can here it again. It's weird.
04-16-2013, 08:23 PM | #9 |
28
Rep 146
I just noticed this exact issue. It sounds like it's coming from behind the stereo. Is this an issue that has to be fixed? It's weird because all winter long I didnt' hear it. Today was 80 degrees, and it's the first time I've heard it. Is this normal?
08-07-2013, 07:33 AM | #10 |
Rep 12
I have been ignoring it, but from time to time it does bother you when all you want is total quietness.
Went to a dealer today and they told me it is the fan for the ecu, asked if anything can be done , he said "nothing to worry about, the fan is part of the main computer and the whole unit costs a couple grand, i wouldn't touch it" asked if i can at least take it out and clean it or lube it, he said no! If anyone has found a solution (affordable) for it, plz share!! |
09-04-2013, 01:01 AM | #13 |
Rep 3
If it's the AC blower fan, I have solved this issue by changing my windshield wiper fluid. Empty the old fluid by using the windshield wiper sprayer and then fill the windshield wiper fluid with the orange [all winter/low temp] fluid. The car takes more than one gallon but less than two gallons. Then mess around with the AC blower fan speed setting until it doesn't make noise.
