F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Enabling Office function in NBT
ARMA SPEED
      04-10-2013, 11:10 AM   #1
Kapitein Iglo
16
Drives: F31
Hi all,
Last friday I took delivery of my Belgium-spec 316d.
Since I ordered the 609 Prof. GPS System, I got the new NBT hardware.
Since the salesman told me the only added function of 6NK over 6NH was audio over bluetooth and I don't really need this, I skipped this pricey option.
Now it turns out also the Bluetooth Office functions (eg email, sms etc) are also part of this 6NH upgrade - at least for the BE market.
Has anyone found this in the coding options for the NBT system?
      04-11-2013, 01:40 PM   #2
cronek
Drives: '12 F31 320d
pm me your email and I can send you my cafd files.
      04-11-2013, 07:48 PM   #3
vithy
56
Drives: 2016 F30 328xi
Can Office be activated with 6NH? or do I need Combox for this? I have base 6NH no Nav.
      04-13-2013, 08:51 PM   #4
alf233
Drives: 2013 328 xDrive
Would like to know as well
      04-14-2013, 03:43 AM   #5
Kapitein Iglo
16
Drives: F31
After some research, found out it might be enabled by changing 6NH to 6NK. Think combobox will be necessary (not applicable with NBT nav)
Might need changes to ADRESSBOOK and MACRO_PIM.
Needs testing but don't have cable and EST token atm
      04-24-2013, 07:52 PM   #6
alf233
Hey Kapitein,
did you do any more testing on this?
      04-25-2013, 01:12 PM   #7
Kapitein Iglo
16
Drives: F31
Originally Posted by alf233 View Post
Hey Kapitein,
Will test this on saturday!
      04-27-2013, 08:49 AM   #8
Kapitein Iglo
16
Drives: F31
So, as promised, the results.
Change VO from 6NH to 6NK and coded the HU_NBT
Enabled some parameters (changed to "true"):
3002 PIM_PARAMETER
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
REMINDER_TRIGGERS_EIN_AUS
MACRO_PIM > this actually show the word OFFICE in idrive menu
Office function seems to work for new incoming email and text. Haven't been able to view calendar items, but I don't know if this is supported without the Apps?
      04-28-2013, 04:50 PM   #9
alf233
Nice job
3002 PIM_PARAMETER
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
      04-29-2013, 02:21 AM   #10
Kapitein Iglo
16
Drives: F31
Can anyone with Office standard enabled on their NBT confirm what works/does not work with the iPhone?
      07-18-2013, 08:21 PM   #11
hillperson
China
Drives: BMW F30 328i Sport Line
Changing the 6NH to 6NK can also solve the bluetooth audio issue?
My 328i have 609, 6NH, 6NR. As other post, 609 should include the BT audio, but I can not use it and find the BT audio option in iDrive.
      07-20-2013, 03:41 AM   #12
Kapitein Iglo
16
Drives: F31
You must first activate bluetooth audio in the bluetooth pairing options of your phone in the iDrive
      07-20-2013, 10:58 AM   #13
hillperson
China
There is no Audio option, only phone. When I finished paring, and go to the device option.
      07-20-2013, 11:35 AM   #14
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
663
Drives: 2020 G20 320i M Sport
Yes, if you change 6NH to 6NK on your VO, you will have Bluetooth Audio and Office but you must have 609 in order for this to work. This works for both HU_CIC and HU_NBT.
      07-21-2013, 08:44 AM   #15
hillperson
China
I have 609 on my list, but when I try to change VO from 6NH to 6NK, and code HU_NBT, there is a error "cafd_00000ded-002_002_008 not executable".
And if I add 6NK into the VO list, keep 6NH and 6NK exist together, then I can code HU_NBT successfully, there is no error. And I can also see the bluetooth and office in the menu, but they can not work. Maybe because 6NH still exist in the VO list.
So I don't know where is the problem, I can only add 6NK, but can not change 6NH to 6NK.......
BTW: I have 609, 6NH, 6NR in my vehicle.
      07-21-2013, 11:02 AM   #16
steve@codemybimmer
Hong Kong
663
You can't have 6NK and 6NH together. As for VO coding HU_NBT, what's your I-step and what version of the psdzdata files are you using?
      07-22-2013, 08:07 AM   #17
hillperson
China
My ESys is 3.22.5, Psdzdata is 49.4.
And the I-step is F020-13-03-503
Thanks
      07-25-2013, 11:05 PM   #18
shag
pullin a boat
shag's Avatar
37
Drives: 2021 X3 M40i
Try coding 6NS instead. 6NK is incompatible with HU_NBT iirc.
2021 X3 M40i, Phytonic/Cognac
Past:
2017 330i xDrive Touring M Sport, EBII, Dinan
2014 328d xDrive Touring M Sport, BSM/CR.
      07-26-2013, 01:31 AM   #19
RSC27
Drives: 320D M Sport
Is it 6NK or 6NS that will work?
I've read that 6nk has worked but when I spoke to BMW they've said 6ns is what I should have had.
Thanks
      07-26-2013, 06:51 AM   #20
shag
pullin a boat
shag's Avatar
37
Thanks
Most if not all NBT-equipped cars with Office functionality seem to use 6NS afaik... Try that & post your results!
Past:
      07-26-2013, 10:47 AM   #21
hillperson
China
Thanks
I will post the result after my trial.
      07-26-2013, 10:50 AM   #22
hillperson
China
BTW: You mean I change 6NH to 6NS and code HU_NBT? I want to confirm that.
Search this Thread:
Advanced Search
f30post
