caster vs camber
04-04-2013, 10:34 AM | #1 |
104
Rep 1,529
caster vs camber
Hey guys...ive been really wondering about whether I should decrease caster to get more camber. Question is would it be better to do it or should I just keep my max caster and then get the most camber afterwards?
Ive been doing some searching and seems like caster only really helps with high speed stability but if you think about some geometry...the more caster you have when you turn your steering wheel you will have more camber automatically. Basically more camber? or more caster?
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
04-05-2013, 01:16 PM | #2 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
You're correct, dynamic camber > static camber. Keep max caster...
What's your camber as it sits now? |
04-05-2013, 01:48 PM | #3 |
104
Rep 1,529
Like -1.4 or so... but tc Kline actually chimed in on my other thread and said to get to-2.4 camber then get as much caster after that
