F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Rust on disc hubs ????????
Studio RSR
      04-03-2013, 11:49 AM   #1
Commanderke
Drives: /
Noticed this today :
10.000km's on salty roads taking is toll ?
Let's visit the dealership tommorow !!
      04-03-2013, 06:00 PM   #2
el_macc
19
Drives: F30 335i
im starting to have the same issue. let me knnow what they say please..
thanx
      04-03-2013, 06:13 PM   #3
Seagull
Seagull's Avatar
289
Drives: F87 M2, E84 X1
Ouch! let me check mine! Hope they deal with it!
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      04-03-2013, 06:33 PM   #4
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
Normal man...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      04-03-2013, 06:48 PM   #5
1bad335
15
Drives: 2007 335I/ 2012 335I sportline
Originally Posted by shivaswrath View Post
Normal man...
Unfortunately you are right. The only way around it is to pull the wheels, mask it all off and paint with high temp black paint. BMW will not warranty that so don't waste your time and effort OP.
      04-03-2013, 07:03 PM   #6
claykin
1588
Drives: various BMW
Correct, but let me add first you need to grind/sand that rusty stuff off (and get it all off as rust is a cancer) then prime with a galvanizing primer before painting with high temp paint.
Then that will only get you a year or two before the paint will likely begin to fail and rust will resume.
Only solution is to replace with aftermarket rotors made of better quality metals. Good luck with that!
2023 840GC | 2021 740i | 2019 X3
      04-03-2013, 07:10 PM   #7
1bad335
15
True all across the board there. Primer would be self etching primer and sanding the rust off is a for sure must too. If done right it should last for awhile but I do agree it will fail at some point.Good points.
      04-03-2013, 07:35 PM   #8
ixse
238
Drives: 2015 boxster s
Normal man...
+1. Won't hurt the performance.. nor it vould cause any dmg.. just close your one eye n pretend its not there
      04-04-2013, 07:23 AM   #9
Commanderke
Drives: /
Took it too the dealership and indeed seems to be 'normal'. They made the same suggestions as mentioned here.
Oh and a story about nature pollutant paint being too harmfull for use in the factory.........blah,blah,blah........
      04-07-2013, 11:55 PM   #10
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
it is true though...
don't know about the states but in canada oil based car paint is prohibited due to the "effects on the environment". thats why if you look at your car's paint its dimpled now instead of nice and flat on pre 2005 cars.
      04-08-2013, 12:07 AM   #11
inChargeOfIT
17
Drives: 2013 335i Sport
The same happens down south (Texas) as well, just not as bad. I was told it was normal as well, and from reading the boards, it seems to be normal across all bimmers.
Unfortunate that they do not coat these pieces since a lot of rims have wide gaps between the spokes. Especially if they are selling $4-$7k rims mostly for looks.
      04-11-2013, 06:56 AM   #12
Sillhuvet
Sillhuvet's Avatar
Drives: 328i F30
This is how mine look without the rims. Some zinkpaste or grease would have been nice in the center. :-(
      04-12-2013, 02:20 PM   #13
F30form
18
Drives: '13 Mini Cooper S Hardtop
This happens to ALL CARS. All of them. Unless the hubs are aluminum. When exposed metal parts go through heat cycling, they attract moisture. This is normal. Find a real issue...
      04-22-2013, 03:07 AM   #14
Sillhuvet
Sillhuvet's Avatar
Drives: 328i F30
Thats true, but zinkpaste would slow the process down significantly. To leave it completly dry from the dealer is just sloppy imo.
      04-25-2013, 04:31 AM   #15
Baz P
Drives: Imperial Blue Xirallic 320D SE
Are you sure? I had two E90s and it wasn't at all noticeable and I checked out a 1-Series in a car park yesterday which was manufactured before mine and they were as clean as a whistle. My 1994 5-series had covered just under 200,000 miles when we parted company and they didn't look such a mess. Mine look bloody awful after 6,000 miles (much worse than the photo from the OP) as do all of the caliper fittings.
I think spending tens of thousands on what is supposed to be a prestigious car and seeing rusty hubs spoiling the look is a real issue. Perhaps symptomatic of keeping prices within reason by cutting back on the integrity of materials or finishing processes?
      05-20-2013, 03:33 PM   #16
steve zzr
Drives: 2016 F10 535d m sport
Rusty Brake And Hub Parts
i agree, my 2012 f30 330d has done 7000miles though winter and the calipars and disc hubs look like they are 10 yrs old.
the quality of the parts are no better than ford/gm, the only solution would be to coat them with a good quality brake calipar paint when the car is new, but it should not necessary on a car costing this much! and i have to say that the paint quality in general is poor for a prestigious brand like BMW.
I am now in a 2013 330d as the first one was replaced by BMW UK due to paint issues, and the replacement car is not a lot better than the first one,
quite dissapointing really.
      05-20-2013, 08:26 PM   #17
Canuck72
Drives: 2012 320i
are the M-performance brake kit hubs aluminum? or would they too be subject to the same rust issue as the standard hub and rotors?
      05-25-2013, 07:39 PM   #18
Musashi
136
Drives: BMW 335i XDrive Laguna Seca
best option is zinc coating...
I do not know about other cities, but in Ottawa I could just take them at KVR and they can perform a zinc coating. Essentially $ 20/disc, it is a 2 day process and the discs are dipped in a liquid an electrical current used to coat them grey black or gold. Any zinc coated set I had never ever rusted and have over 100 000 kms winter driving to use as reference. Obviously I will not do this on a first set of discs, but the replacement, in advance; Zimmer rotors etc. The difference is astonishing. To the readers, a reminder: when I say that I never had zinc coated rust, I am talking daily driving in a nasty salty Canadian winter.
I addition, zinc coating has two other advantages:
1- Discs never rust on the inside, or between the front rotor plates, or from the inside out (happened to me once on a set that accidentally sat 8 hrs in a pool of water (torrential rain) and they crumbled from within in 5 months!)
2- Will never chip or crack like a paint, and not relative to rotor temperature.
What is mystifying is why does BMW not do this as standard... I suspect maybe on the higher end M performance..
All the best
      05-25-2013, 07:54 PM   #19
Musashi
136
[QUOTE=Sillhuvet;13801822]This is how mine look without the rims. Some zinkpaste or grease would have been nice in the center. :-(
Attached an old image of a Canadian made KVR zinc coated rotor. At the time the calipers had seized. Rotor had 50 000 kms and two winters- note- NO RUST on the hub. With the new calipers the rotor surface was again shiny.
      05-30-2013, 08:07 PM   #20
guitarplayax
Drives: BMW 2013 328i xDrive
If this is normal, then why didn't it happen to the 5 cars I have previously owned?
      05-31-2013, 01:18 AM   #21
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
maybe you didn't like the old cars and didn't pay attention to the details.
G05 - M Performance roof spoiler
      05-31-2013, 10:58 AM   #22
guitarplayax
Hey! I loved my previous cars! They all had a black powder coating (I think) on the rotor hub to prevent this nonsense.
f30post
